@BulldogLowell said I should be able to set a variable that is used in a function. With that in mind after some sleuthing I found the post [Tutorial] below and was able to set the Variable mysleepyTime through a Function setsleeptime in my code down below. Again, it works. If I enter a value in setsleeptime function, then enter “sleep” in the sleep function it’ll sleep for that long! Yippee!
Here’s what I don’t understand. I don’t get a cloud variable for getsleepytime Nothing shows up even if I do a CLI particle list I don’t see it listed. I kinda was expecting I could see whatever value I had last entered in setsleeptime And when ever I enter a Parameter for setsleeptime the Result is always 0.
-Jose
The inspiration:
Continuing the discussion from Tutorial: Spark Variable and Function on One Web Page:
[quote=“bko, post:5, topic:4181, full:false”]…
int myParam = 0; // or other initial value
Spark.function(“setparam”, setParam);
Spark.variable(“getparam”, &myParam, INT);
// whatever other setup you need
//you code that uses myParam
int setParam(String paramValue) {
myParam = paramValue.toInt();
return 0;
[/quote]
Here’s my interpretation:
// Variable to set sleep duration in minutes
int mysleepyTime = 0;
// Bunch of pin declarations
Serial.begin(9600); // Initialize serial communications with the PC
// These functions are useful for remote diagnostics. Read more below.
Particle.function("sleep", sleepMode);
Particle.function("setsleeptime", setsleepTime);
Particle.variable("getsleepytime", &mysleepyTime, INT);
void loop(){
//The Loop
int setsleepTime(String paramValue) {
mysleepyTime = paramValue.toInt();
return 0;
// Lets you remotely invoke sleep mode by calling the function "sleep"
int sleepMode(String command){
if(command == "sleep")
System.sleep(SLEEP_MODE_DEEP, mysleepyTime * 60);
return 1;
else return -1;
