[SOLVED] Particle photon + neopixel + adafruit.io
Hi , guys
currently , I’m making a simple project controlling a neopixel by photon via adafruit.io dashboard
but the code not working and I can’t understand how to fix it : here is my code :
I know that photon connects to wifi on its own so that I don’t need to create a client but the
adafruit’s code needs one , I don’t know if i got this well or not , so any ideas , help ? :smiley:
By the way this was a code for esp but I wanted to modify it so it can fit in photon :smiley:
#include <TlsTcpClient.h>
#include <Adafruit_MQTT.h>
#include <neopixel.h>
 #include "Particle.h"
/************************* WiFi Access Point *********************************/
 SYSTEM_MODE(AUTOMATIC);
//#define WLAN_SSID       "SSID"
//#define WLAN_PASS       "password"
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883   //1883 is the standard port for MQTT    // use 8883 for SSL
#define AIO_USERNAME    "User Name"
#define AIO_KEY         "AIO KEY"
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
TCPClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_SPARK mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
 //neopixel
 #define PIXEL_PIN D2
 #define PIXEL_COUNT 1
 #define PIXEL_TYPE WS2812B
 Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
 Adafruit_MQTT_Subscribe r-value = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/r-value");
 Adafruit_MQTT_Subscribe g-value = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/g-value");
 Adafruit_MQTT_Subscribe b-value = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/b-value");
void MQTT_connect();
//vars
int r = 0  , g = 0  , b = 0 ;
 /* WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
  //subscribtion
  mqtt.subscribe(&r-value);
  mqtt.subscribe(&g-value);
  mqtt.subscribe(&b-value);
  //NEO
  strip.begin();
  strip.setPixelColor(0, pixels.Color( r,g,b ));
  strip.show();
    MQTT_connect();
    Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(5000))) {
    if (subscription == &r-value) {
      r = r-value.lastread
        if (subscription == &g-value) {
      g = g-value.lastread
        if (subscription == &b-value) {
      b = b-value.lastread
    strip.setPixelColor(0, strip.Color( r,g,b ));
    strip.show();
A more precise description what "not working" means is required before going on a wild goose (or red herring) chase.
So , What should I do ?
Explain what doesn’t work.
BTW, I’m pretty sure there are no minus signs (-) allowed in variable names.
Hence I guess you get compiler errors and hence posting these error messages would be the least to do in order to explain the nature of your problem.
these are the errors I got
I think the problem is , I can’t use adafruit mqtt library as with esp
I can’t understand the differences , I can’t find a good a example to follow .
also , I think there are some missing concepts with moving from arduino to photon I didn’t know yet
I know this isn’t much help, but can you try choosing the MQTT library again and installing it on your app for Photon. Sometimes I forget to re-load a library, especially if I’m copying code from a previous app or snippet. Even though it says the library is there, it may not actually be getting it on the Photon. If that doesn’t help, I would post on Adafruit’s forum. :slight_smile:
There are more things to do to your code.
Some of these could be found by looking at the examples that come with the libraries.
e.g. add this
#include <Adafruit_MQTT_SPARK.h>
(This is some design flaw in the lib, but can be dealt with this way)
With that you will get a step further and the errors you’ll be getting then should not pose too much of trouble :wink:
Update:
Looking beyond these errors, it seems that not even the Adafruit_MQTT sample builds, so I guess this lib needs some major overhaul, but since the source repo has disappeared it seems unlikely this lib will ever get repaired.
I could solve the problem partially : what misses it transforming the subscription to integer
here is the code
P.S. checks @Zengirl2 comment before flashing this code
    #include "Adafruit_MQTT_SPARK.h"
    #include "Adafruit_MQTT.h"
    #define AIO_SERVERPORT  1883                   // use 8883 for SSL
    #define AIO_USERNAME    "...your AIO username (see https://accounts.adafruit.com)..."
    #define AIO_KEY         "...your AIO key..."
    TCPClient TheClient;
    Adafruit_MQTT_SPARK mqtt(&TheClient,AIO_SERVER,AIO_SERVERPORT,AIO_USERNAME,AIO_KEY);
     //neopixel
     Adafruit_MQTT_Subscribe rvalue = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/r-value");
     Adafruit_MQTT_Subscribe gvalue = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/g-value");
     Adafruit_MQTT_Subscribe bvalue = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/b-value");
    //vars
        delay(500);
      //subscribtion
      mqtt.subscribe(&rvalue);
      mqtt.subscribe(&gvalue);
      mqtt.subscribe(&bvalue);
      //NEO
      strip.begin();
      strip.show();
        if( mqtt.Update() )
            // this is our 'wait for incoming subscription packets' busy subloop
            // try to spend your time here
        if (subscription == &rvalue) {
          r = (int)rvalue.lastread ;
            if (subscription == &gvalue) {
          g = (int)gvalue.lastread ;
            if (subscription == &bvalue) {
          b = (int)bvalue.lastread ;
        strip.show();
            // ping the server to keep the mqtt connection alive
            // NOT required if you are publishing once every KEEPALIVE seconds
            if(! mqtt.ping())
                mqtt.disconnect();
this example helped alot : https://build.particle.io/libs/Adafruit_MQTT/1.6.1/tab/example/adafruit-mqtt-spark-test.ino
How does your raw subscription return value look like?
I think it’s string maybe a char pointer " I don’t know alot about code "
from the online code that I had linked to in my previous replay
if (subscription == &onoffbutton)
                Serial.print(F("Got: "));
                Serial.println((char *)onoffbutton.lastread);
It is very important to know how the raw return values are made up to properly translate the binary package into the correct representation for your code.
