[SOLVED] Not able to put my core in stop mode (it just wakes up)
One more shot into the blue
Could you try to power your Core of a “wall wart” or some other way than your laptop?
You read my mind!
I flashed your code and tried powering the Core with a LiPo batery trough a 5v booster. Nothing changed. Then I connected the battery directly to the Core. Still the same
@netropo,
can you try this example:
void setup(){
    pinMode(D7,OUTPUT);
    digitalWrite(D7,HIGH);
    delay(1000);
    digitalWrite(D7,LOW);
    delay(1000);
    Spark.sleep(SLEEP_MODE_DEEP,60);
The behavior should be flashing green --> breathing cyan --> blue led on 1s --> blue led off --> sleep for 60s
Just want to confirm that your bootloader is fine :wink: If not, a simple patch will do the job :smiley:
Sorry for my ausence @kennethlimcp but yesterday a sort of community restriction was taking place against my user preventing me to post and even to send private messages!
I will reproduce here the conversation we had by private messages, just for the shake of documenting the problem.
The code above worked as expected, that is, my Core connected to wifi, led was on for 1 second, then off, then slept for 60 seconds, then wake up again.
By message you asked me to try this code as well
void setup(){
  pinMode(D7,OUTPUT);
  delay(1000);
  delay(1000);
  Spark.sleep(D0,RISING);
With that code flashed my core goes to sleep but after few seconds wakes up again
Hello again :wink:
And we are back to the INPUT_PULLDOWN thing again - D0 is not allowed to float!!!
Hi again @ScruffR!
You are absolutelly right. But even with the internal pull down resistor enabled the Core still wakes up. Could I use a regular resistor to ground to discard internal resistors missfunction? Any idea about the required value?
Thank you all for your patience and dedication to this weird problem by the way :smile:
Yes you could use a regular resistor. For this simple test any value would do, but 4k7 is never a bad choice :wink:
But I don’t think it will change anything anyhow (you tested several pins and I wouldn’t expect multiple pull-downs to be gone at once) - since the last code I posted works perfectly well on my Cores but doesn’t on yours, I’d expect you have some kind of hardware or Spark internal firmware issue.
Maybe you try some more factory resets and also a CC3000 deep_update (won’t have anything to do with this issue, but just to have it off the list).
I guess you haven’t got another Core to test it with :wink:
It somehow seems to me as if some other interrupt (~2sec) keeps waking the Core - but I have no idea which and how to nail it.
Browsing Github issues I’ve found this, which looks the same as my problem (comment #issuecomment-52681926)
Apparently it was solved in the bootloader patch but since I am having the same problem maybe it has returned altough the code does not seem to have been updated since 5 months ago.
Definetely that is the problem I am experimenting
And now… ITS WORKING! ^^
So, sumarizing:
In the begining I did not apply the bootloader patch even when I thought I did. What I did instead is flashing my Core with the master branch bin by error.
In my opinion, if bootloader patch is a production ready code should be merged into master branch and tagged.
However, if there is a reason for no doing so the documentation should be updated to point the need of switching to a branch before flashing since it not obvious if you follow README.md instructions
Anyways I am quite happy to see it solved since stop mode is a key feature in many projects I have in mind. Thank you all for your valuable time and dedication :smiley:
Would you mind explaining the exact steps you took to fix this problem? I’m not sure most of our users (myself included) would understand what you had to do to get this working. Thanks!
Sure!
Users who experiment the same problem just need to flash the core using the bootloader-patch-update branch of the firmware:
git clone git@github.com:spark/firmware
cd firmware
git checkout bootloader-patch-update
cd core-firmware/build
Then enter usb dfu/bootloader mode and flash their Core by executing
dfu-util -d 1d50:607f -a 0 -s 0x08005000:leave -D core-firmware.bin
Is there a reason why that branch is not merged back into master? I think that it would help to avoid other users to get confused
Thanks for the steps. There’s an entire bootloader branch (https://github.com/spark/bootloader) but I’m not sure that’s related. Do you need to keep building with that special branch or is it a one time fix?
Seems to be a one time fix, since I’ve flashed a test project via web and behaviour remains as expected
That’s really strange. Did you have to unlock your bootloader first?
Nop, no aditional steps were needed
Awesome! That’s the step I was about to recommend if you are still facing the same issue.
You probably bought a core some time back and the bootloader is of an older version :wink:
Yes, but doesn’t he had to unlock the bootloader to upgrade it? Unless… the firmware he flashed does that automatically…
I think @satishgn made a special version of the core firmware that just patched the bootloader and that is what @netropo ran.
I thought that the “deep update” TI patcher also changed the bootloader, but I am not completely sure. It was discussed for sure but I am not sure what the decision was.
This only comes up for older cores since the newer production models have the newer bootloader.
Glad it is fixed.
So for learning purposes, take a look here: https://github.com/spark/firmware/commit/30d618147fdf19ea0fd5bd8f7e96c5775e113b2a#diff-7ec3c68a81efff79b6ca22ac1f1eabbaR1246
The entire bin data is in the user firmware itself and the firmware will unlock, erase and overwrite the existing bootloader region.
There’s some obvious risk here but i remembered timing the entire process but cannot locate the timings for this. It’s in the range where the patch get completed upon powering up and before the power can even be cut off :wink:
Interesting.
I’ll check later myself but is that code snippet you linked me to run every time firmware is downloaded to the device (checking to see if the bootloader is patched)? Or is that just for that particular branch OP linked to?
