[SOLVED] Install error in ATOM when installing particle-dev-local-compiler dependencies
Getting this error since yesterday. Seems like something in the dev prfiles addon is breaking status bar.
[Enter steps to reproduce below:]
Atom Version: 1.11.1
Electron Version: 0.37.8
System: Microsoft Windows 10 Home
Thrown From: status-bar package, v1.4.1
Stack Trace
Failed to activate the status-bar package
At Arguments to CompositeDisposable.add must have a .dispose() method
TypeError: Arguments to CompositeDisposable.add must have a .dispose() method
    at assertDisposable (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\node_modules\event-kit\lib\composite-disposable.js:70:13)
    at CompositeDisposable.module.exports.CompositeDisposable.add (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\node_modules\event-kit\lib\composite-disposable.js:43:11)
    at ProfilesTile.initialize (C:/Users/Ali/.atom/packages/particle-dev-profiles/src/profiles-tile.js:23:22)
    at ProfilesTile.View [as constructor] (C:\Users\Ali\.atom\packages\particle-dev-profiles\node_modules\space-pen\lib\space-pen.js:184:25)
    at new ProfilesTile (C:/Users/Ali/.atom/packages/particle-dev-profiles/src/profiles-tile.js:8:34)
    at Object.consumeStatusBar (C:/Users/Ali/.atom/packages/particle-dev-profiles/src/main.js:27:10)
    at Provider.module.exports.Provider.provide (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\node_modules\service-hub\lib\provider.js:29:52)
    at ServiceHub.module.exports.ServiceHub.provide (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\node_modules\service-hub\lib\service-hub.js:30:20)
    at Package.module.exports.Package.activateServices (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package.js:355:71)
    at Package.module.exports.Package.activateNow (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package.js:186:16)
    at C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package.js:156:32
    at Package.module.exports.Package.measure (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package.js:92:15)
    at C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package.js:149:26
    at Package.module.exports.Package.activate (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package.js:146:34)
    at PackageManager.module.exports.PackageManager.activatePackage (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package-manager.js:538:21)
    at C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package-manager.js:519:29
    at Config.module.exports.Config.transactAsync (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\config.js:337:18)
    at PackageManager.module.exports.PackageManager.activatePackages (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package-manager.js:514:19)
    at PackageManager.module.exports.PackageManager.activate (C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\package-manager.js:497:46)
    at C:\Users\Ali\AppData\Local\atom\app-1.11.1\resources\app.asar\src\atom-environment.js:779:28
Commands
     -0:01.1.0 particle-dev:update-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
     -0:01.1.0 particle-dev:append-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
Config
  "core": {
    "telemetryConsent": "no"
Installed Packages
# User
console-panel, v0.2.0 (inactive)
particle-dev, v0.1.5 (inactive)
particle-dev-cloud-functions, v0.1.0 (inactive)
particle-dev-cloud-variables, v0.1.0 (inactive)
particle-dev-complete, v1.0.0 (inactive)
particle-dev-profiles, v0.1.6 (inactive)
tool-bar, v1.0.1 (inactive)
atom-dark-syntax, v0.27.0 (inactive)
atom-dark-ui, v0.52.0 (inactive)
atom-light-syntax, v0.28.0 (inactive)
atom-light-ui, v0.44.0 (inactive)
base16-tomorrow-dark-theme, v1.2.0 (inactive)
base16-tomorrow-light-theme, v1.2.0 (inactive)
one-dark-ui, v1.6.0 (inactive)
one-light-ui, v1.6.0 (inactive)
one-dark-syntax, v1.3.0 (inactive)
one-light-syntax, v1.3.0 (inactive)
solarized-dark-syntax, v1.0.2 (inactive)
solarized-light-syntax, v1.0.2 (inactive)
about, v1.7.0 (inactive)
archive-view, v0.61.1 (inactive)
autocomplete-atom-api, v0.10.0 (inactive)
autocomplete-css, v0.11.2 (inactive)
autocomplete-html, v0.7.2 (inactive)
autocomplete-plus, v2.31.1 (inactive)
autocomplete-snippets, v1.11.0 (inactive)
autoflow, v0.27.0 (inactive)
autosave, v0.23.1 (inactive)
background-tips, v0.26.1 (inactive)
bookmarks, v0.42.0 (inactive)
bracket-matcher, v0.82.1 (inactive)
command-palette, v0.38.0 (inactive)
deprecation-cop, v0.54.1 (inactive)
dev-live-reload, v0.47.0 (inactive)
encoding-selector, v0.22.0 (inactive)
exception-reporting, v0.40.0 (inactive)
find-and-replace, v0.201.1 (inactive)
fuzzy-finder, v1.4.0 (inactive)
git-diff, v1.1.0 (inactive)
go-to-line, v0.31.0 (inactive)
grammar-selector, v0.48.2 (inactive)
image-view, v0.59.0 (inactive)
incompatible-packages, v0.26.1 (inactive)
keybinding-resolver, v0.35.0 (inactive)
line-ending-selector, v0.5.0 (inactive)
link, v0.31.1 (inactive)
markdown-preview, v0.158.0 (inactive)
metrics, v1.0.0 (inactive)
notifications, v0.65.1 (inactive)
open-on-github, v1.2.0 (inactive)
package-generator, v1.0.0 (inactive)
settings-view, v0.242.2 (inactive)
snippets, v1.0.2 (inactive)
spell-check, v0.68.2 (inactive)
status-bar, v1.4.1 (inactive)
styleguide, v0.47.0 (inactive)
symbols-view, v0.113.1 (inactive)
tabs, v0.101.0 (inactive)
timecop, v0.33.2 (inactive)
tree-view, v0.209.3 (inactive)
update-package-dependencies, v0.10.0 (inactive)
welcome, v0.35.1 (inactive)
whitespace, v0.33.0 (inactive)
wrap-guide, v0.38.2 (inactive)
language-c, v0.52.1 (inactive)
language-clojure, v0.21.0 (inactive)
language-coffee-script, v0.47.2 (inactive)
language-csharp, v0.12.1 (inactive)
language-css, v0.37.1 (inactive)
language-gfm, v0.88.0 (inactive)
language-git, v0.15.0 (inactive)
language-go, v0.42.1 (inactive)
language-html, v0.45.1 (inactive)
language-hyperlink, v0.16.0 (inactive)
language-java, v0.23.0 (inactive)
language-javascript, v0.119.0 (inactive)
language-json, v0.18.2 (inactive)
language-less, v0.29.5 (inactive)
language-make, v0.22.2 (inactive)
language-mustache, v0.13.0 (inactive)
language-objective-c, v0.15.1 (inactive)
language-perl, v0.35.0 (inactive)
language-php, v0.37.2 (inactive)
language-property-list, v0.8.0 (inactive)
language-python, v0.45.0 (inactive)
language-ruby, v0.69.0 (inactive)
language-ruby-on-rails, v0.25.0 (inactive)
language-sass, v0.56.0 (inactive)
language-shellscript, v0.22.4 (inactive)
language-source, v0.9.0 (inactive)
language-sql, v0.23.0 (inactive)
language-text, v0.7.1 (inactive)
language-todo, v0.28.0 (inactive)
language-toml, v0.18.0 (inactive)
language-xml, v0.34.9 (inactive)
language-yaml, v0.26.0 (inactive)
# Dev
No dev packages
Thx Ali! We’ll look into this!
Any insight into the error I have (see above)?
Just released version 0.1.8 which should fix this issue :slight_smile:
This error shows up on the Atom editor. The butons on functions and variables dont show anymore. Is there a way to fix this?
Hi Ali! This was caused by a different bug. Just released v0.1.17 which should fix it!
Hello,
I’m new to the IDE. I had the same issue. Uninstalling atom or the particle dev, or reinstalling them, do not solve the issues. I did a chmod to the .particle folder inside my home (~) and it worked like a charm!
