[SOLVED] Getting the ST7735 to work with Spark
I am using the Web IDE.
I tried with first suggestion above #define cs 12 etc. - that worked.
Then I tried #define cs A2 etc. - that worked and it didn’t before.
I will look in the other threads as you suggest - thanks for your advice.
