Here’s the entirety of my code. I’m sure there are lots of bugs, just trying to work through them one-by-one
#include "Adafruit_RGBLCDShield/Adafruit_RGBLCDShield.h"
#include "Adafruit_RGBLCDShield/Adafruit_MCP23017.h"
//dryer v3 uses the adafruit dht library since the pietteTech lib seems to have stopped working? -it just reads -5.00 all the time
//I've also updated the rgblcdshield lib, but no improvement
#include "Adafruit_DHT/Adafruit_DHT.h"
//#include "PietteTech_DHT/PietteTech_DHT.h"
#include "math.h"
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // Sensor type DHT11/21/22/AM2301/AM2302
//includes
//define pins
#define DHTPIN 3 // what pin we're connected to
#define ON 0x7
#define OFF 0x0
//inititalize dht temp sensor and lcd shield
//void dht_wrapper(); // must be declared before the lib initialization
// Lib instantiate
//PietteTech_DHT DHT(DHTPIN, DHTTYPE, dht_wrapper);
DHT dht(DHTPIN, DHTTYPE); //adafruit dht init
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
//initialize icons
byte icons[3][7] = {{ 0x0, 0x4, 0x6, 0x1f, 0x6, 0x4, 0x0},
{0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0},
{0x4, 0xe, 0xe, 0x1e, 0x1b, 0xb, 0x6}
//! Index into the bitmap array for the icons.
const int ARROW_ICON_IDX = 0;
const int CLOCK_ICON_IDX = 1;
const int FLAME_ICON_IDX = 2;
//constants
const long meas_interval = 3000;
const int motorPin = 7;
const int heaterPin = A5;
const long heater_timeout_interval = 120000; //2 minute lockout
const long time_interval = 3000; //check how much time left every 3 seconds
const long temp_interval = 3000; //check what to set temp to every 3 seconds
//variables
uint8_t clicked_buttons;
int menu = 0;
unsigned long previous_print_millis;
const unsigned long printInterval = 3000;
unsigned long heater_last_used_millis;
int motorState = LOW;
int heaterState = LOW;
boolean heater_timeout = false;
unsigned long previous_meas_millis = 0;
String currentMode;
unsigned long previous_time_millis = 0;
unsigned long previous_temp_millis = 0;
float inside_temp;
float inside_moisture;
int time_remaining = 60;
int temp_setpoint = 101;
unsigned long currentMillis;
unsigned long cooldown_start_millis = 0;
unsigned long cooldown_interval = 300000;
//button variables
int buttonPin = 6; // the number of the input pin
int reading; // the current reading from the input pin
int buttonPrevious = LOW;
//variables and constants for moving average of moisture
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int reading_idx = 0; // the index of the current reading
int total = 0; // the running total
int average_moisture = 0; // the average
//variables for time and temp selections
String run_selected;
String temp_selected;
String time_selected;
int run_type = 0;
int prev_time_remaining = 0;
unsigned long previous_run_millis = 0;
unsigned long time_elapsed = 0;
/*--- *****setup****** ---*/
lcd.begin(16, 2);
lcd.createChar(ARROW_ICON_IDX, icons[ARROW_ICON_IDX]);
lcd.createChar(CLOCK_ICON_IDX, icons[CLOCK_ICON_IDX]);
lcd.createChar(FLAME_ICON_IDX, icons[FLAME_ICON_IDX]);
pinMode(motorPin, OUTPUT);
pinMode(heaterPin, OUTPUT);
pinMode(buttonPin, INPUT);
dht.begin(); //adafruit dht start
for (int thisReading = 0; thisReading < numReadings; thisReading++) //initialize counter for moving average of moisture
readings[thisReading] = 0;
lcd.setCursor(0, 0);
lcd.write(FLAME_ICON_IDX);
lcd.write(CLOCK_ICON_IDX);
lcd.print(" Welcome to ");
lcd.setCursor(2, 1);
lcd.print("Dryerbot9000");
delay(2000);
lcd.clear();
menu_fun();
//void dht_wrapper() {
// DHT.isrCallback();
float read_inside_temp() {
//float t = dht.readTemperature();
// Read temperature as farenheit
inside_temp = dht.getTempFarenheit();
// Check if any reads failed and exit early (to try again).
if (isnan(inside_temp)) {
//lcd.print("Failed to read from DHT sensor!");
Serial.println("Failed to read from DHT sensor!");
return inside_temp; //?? this was commented out, why?
float read_inside_moisture() {
inside_moisture = dht.getHumidity();
if (isnan(inside_moisture)) {
return inside_moisture;
int auto_heat() {
if (average_moisture >= 52) {
temp_setpoint = 160;
else if ( average_moisture < 52 && average_moisture >= 50) {
temp_setpoint = 150;
else if (average_moisture < 50 && average_moisture >= 47) {
temp_setpoint = 140;
else if (average_moisture < 47 && average_moisture >= 44) {
temp_setpoint = 130;
else if (average_moisture < 44 && average_moisture >= 41) {
temp_setpoint = 120;
else if (average_moisture < 41 && average_moisture >= 38) {
temp_setpoint = 110;
else if (average_moisture < 38 && average_moisture >= 35) {
temp_setpoint = 100;
else if (average_moisture < 35) {
temp_setpoint = 0;
else {
temp_setpoint = 0;
return temp_setpoint;
int auto_time() {
if (average_moisture >= 53) {
else if (average_moisture < 53 && average_moisture >= 50) {
time_remaining = 50;
time_remaining = 40;
time_remaining = 30;
time_remaining = 20;
time_remaining = 10;
time_remaining = 5;
time_remaining = 0;
else {
return time_remaining;
boolean heater_timeout_check() {
//heaterState = digitalRead(heaterPin);
if (heaterState == HIGH) {
heater_last_used_millis = currentMillis;
else if (heaterState == LOW && (currentMillis - heater_last_used_millis >= heater_timeout_interval)) {
else {
heater_timeout = true;
return heater_timeout;
String run_mode() {
//digitalWrite(motorPin, HIGH);
cooldown_start_millis = currentMillis;
if (time_selected == "auto" && temp_selected == "auto") {
run_type = 0;
else if (time_selected == "auto" && temp_selected.toInt() > 0) {
temp_setpoint = temp_selected.toInt();
run_type = 1;
else if (time_selected.toInt() > 0 && temp_selected == "auto") {
prev_time_remaining = time_selected.toInt(); //convert to number
run_type = 2;
else if (time_selected.toInt() > 0 && temp_selected.toInt() > 0) {
run_type = 3;
else {
run_type = 0;
switch (run_type) {
case 0: //auto time auto heat
if (currentMillis - previous_time_millis >= time_interval) {
previous_time_millis = currentMillis;
auto_time();
if (currentMillis - previous_temp_millis >= temp_interval) {
previous_temp_millis = currentMillis;
auto_heat();
break;
case 1: //auto time set heat
auto_time();
break;
case 2: //set time auto heat
auto_heat();
time_remaining = prev_time_remaining - ((currentMillis - previous_run_millis) * 60000);
previous_run_millis = currentMillis;
break;
case 3: //set time set heat
break;
motorState = HIGH;
heater_timeout_check();
//motorState = digitalRead(motorPin);
if (inside_temp <= temp_setpoint && heater_timeout == false) {
//digitalWrite(heaterPin, HIGH);
heaterState = HIGH;
else {
//digitalWrite(heaterPin, LOW);
heaterState = LOW;
currentMode = "run_mode";
menu = 999;
//else {
// cooldown_mode();
return currentMode;
String cooldown_mode() {
//if (currentMillis - cooldown_start_millis <= cooldown_interval) {
// digitalWrite(motorPin, HIGH);
// digitalWrite(heaterPin,LOW);
motorState = HIGH;
heaterState = LOW;
currentMode = "cooldown_mode";
//else if (temp_setpoint != 0 && time_remaining != 0) {
// run_mode();
// else {
// stop_mode();
return currentMode;
String stop_mode() {
// digitalWrite(heaterPin, LOW);
//digitalWrite(motorPin, LOW);
//cooldown_start_millis = currentMillis;
heaterState = LOW;
motorState = LOW;
time_remaining = 0;
temp_setpoint = 0;
currentMode = "stop_mode";
return currentMode;
void read_button_clicks() {
static uint8_t last_buttons = 0;
uint8_t buttons = lcd.readButtons();
clicked_buttons = (last_buttons ^ buttons) & (~buttons);
last_buttons = buttons;
/*if (clicked_buttons) {
menu_fun();
int prev_menu=-1;
int menu_fun() {
if (clicked_buttons & BUTTON_RIGHT) {
menu++;
if (clicked_buttons & BUTTON_LEFT) {
menu--;
if (menu > 2 && menu < 100) {
menu = 0;
if (menu < 0) {
menu = 2;
if (menu > 106 && menu < 200) {
menu = 101;
if (menu < 101 && menu > 99) {
menu = 106;
if (menu > 205 && menu < 300) {
menu = 201;
if (menu < 201 && menu > 199) {
menu = 205;
switch (menu) {
case 0: //time
//lcd.clear();
lcd.setCursor(0,0);
lcd.write(ARROW_ICON_IDX);
lcd.print("time ");
lcd.print("heat ");
//if (time_selected && temp_selected){
lcd.setCursor(0,1);
lcd.print("time:");
lcd.print(time_selected);
lcd.print(" temp:");
lcd.print(temp_selected);//}
if (clicked_buttons & (BUTTON_SELECT | BUTTON_DOWN)) {
lcd.clear();
menu=101;
break;
case 1: //heat
lcd.setCursor(0,0);
lcd.print(" time");
lcd.print("heat ");
lcd.setCursor(0,1);
lcd.print("time:");
lcd.clear();
menu = 201;
//prev_menu = 1;
break;
case 101: //time auto
lcd.setCursor(0,0);
lcd.print("time ");
lcd.setCursor(0, 1);
lcd.print("Auto 90 60 45 30 15");
if (clicked_buttons & BUTTON_UP) {
lcd.clear();
menu = 0;
if (clicked_buttons & BUTTON_SELECT) {
time_selected = "auto";
lcd.clear();
lcd.print("Auto Time");
delay(1000);
lcd.clear();
menu =1;
break;
case 102: //time 90
lcd.setCursor(0,0);
lcd.print("time ");
lcd.print(" Auto");
lcd.print("90 60 45 30 15");
lcd.clear();
menu = 0;
time_selected = "90";
lcd.clear();
lcd.print("90 Minutes");
delay(1000);
lcd.clear();
menu =1;
break;
case 103: //time 60
lcd.setCursor(0,0);
lcd.print("time ");
lcd.print(" Auto 90");
lcd.print("60 45 30 15");
lcd.clear();
menu = 0;
time_selected = "60";
lcd.clear();
lcd.print("60 Minutes");
delay(1000);
lcd.clear();
menu = 1;
break;
case 104: //time 45
lcd.setCursor(0,0);
lcd.print("time ");
lcd.print(" Auto 90 60");
lcd.print("45 30 15");
lcd.clear();
menu = 0;
time_selected = "45";
lcd.clear();
lcd.print("45 Minutes");
delay(1000);
lcd.clear();
menu =1;
break;
case 105: //time30
lcd.setCursor(0,0);
lcd.print("time ");
lcd.print("90 60 45");
lcd.print("30 15 ");
lcd.clear();
menu = 0;
time_selected = "30";
lcd.clear();
lcd.print("30 Minutes");
delay(1000);
lcd.clear();
menu =1;
break;
case 106: //time 15
lcd.setCursor(0,0);
lcd.print("time ");
lcd.print("90 60 45 30");
lcd.print("15 ");
lcd.clear();
menu = 0;
time_selected = "15";
lcd.clear();
lcd.print("15 Minutes");
delay(1000);
lcd.clear();
menu =1;
break;
case 201: //heat auto
lcd.setCursor(0,0);
lcd.print("heat ");
lcd.print("Auto Hi Med Low Off");
lcd.clear();
menu = 0;
temp_selected = "auto";
lcd.clear();
lcd.print("Auto heat");
delay(1000);
lcd.clear();
menu =0;
break;
case 202: //heat hi
lcd.setCursor(0,0);
lcd.print("heat ");
lcd.print(" Auto");
lcd.print("Hi Med Low Off");
lcd.clear();
menu = 0;
temp_selected = "150";
lcd.clear();
lcd.print("High heat");
delay(1000);
lcd.clear();
menu = 0;
break;
case 203: //heat med
lcd.setCursor(0,0);
lcd.print("heat ");
lcd.print(" Auto Hi");
lcd.print("Med Low Off");
lcd.clear();
menu = 0;
temp_selected = "130";
lcd.clear();
lcd.print("Medium heat");
delay(1000);
lcd.clear();
menu = 0;
break;
case 204: //heat low
lcd.setCursor(0,0);
lcd.print("heat ");
lcd.print("Hi Med");
lcd.print("Low Off ");
lcd.clear();
menu = 0;
temp_selected = "110";
lcd.clear();
lcd.print("Low heat");
delay(1000);
lcd.clear();
menu = 0;
break;
case 205: //heat off
lcd.setCursor(0,0);
lcd.print("heat ");
lcd.print("Hi Med Low");
lcd.print("Off ");
lcd.clear();
menu = 0;
temp_selected = "32";
lcd.clear();
lcd.print("Heat Off");
delay(1000);
lcd.clear();
menu = 0;
break;
case 999: //display in run mode
lcd.setCursor(0,0);
lcd.print(":");
lcd.print(time_remaining);
lcd.print(" dry:");
lcd.print(map(average_moisture,35,100,100,0));
lcd.print(" ");
lcd.print(currentMode);
lcd.setCursor(0,1);
lcd.print("time:");
lcd.clear();
menu=0;
break;
/* --- ******* Loop ****** --- */
delay(10);
lcd.setBacklight(ON);
read_button_clicks();
menu_fun();
currentMillis = millis();
digitalWrite(motorPin, motorState);
digitalWrite(heaterPin, heaterState);
reading = digitalRead(buttonPin);
total = total - readings[reading_idx];
if (currentMillis - previous_meas_millis >= meas_interval) {
previous_meas_millis = currentMillis;
// DHT.acquire();//?? do I need this?
readings[reading_idx] = read_inside_moisture();
read_inside_temp();
total = total + readings[reading_idx];
reading_idx = reading_idx + 1;
if (reading_idx >= numReadings)
reading_idx = 0;
average_moisture = total / numReadings;
//probably need to move these to the run function
//calculate time remaining
auto_time();
auto_heat();
if (reading == HIGH && time_remaining > 0 && temp_setpoint > 0) {
run_mode();
else if (reading == HIGH && (time_remaining == 0 || temp_setpoint == 0) && (currentMillis - cooldown_start_millis <= cooldown_interval)) {
cooldown_mode();
else if (reading == HIGH && currentMode == "cooldown_mode" && (currentMillis - cooldown_start_millis > cooldown_interval)) {
stop_mode();
else if (reading == LOW) {
stop_mode();
else {
stop_mode();
if (currentMillis - previous_print_millis >= printInterval) {
previous_print_millis = currentMillis;
Serial.print("time=");
Serial.print(currentMillis / 1000);
Serial.print(", ");
Serial.print("currentMode=");
Serial.print(currentMode);
Serial.print(", ");
Serial.print("inside_temp=");
Serial.print(inside_temp);
Serial.print(", ");
Serial.print("inside_moisture=");
Serial.print(inside_moisture);
Serial.print(", average= ");
Serial.print(average_moisture);
Serial.print(", ");
Serial.print("time_selected=");
Serial.print(time_selected);
Serial.print(", ");
Serial.print("time_remaining=");
Serial.print(time_remaining);
Serial.print(", ");
Serial.print("temp_selected=");
Serial.print(temp_selected);
Serial.print(", ");
Serial.print("temp_setpoint=");
Serial.print(temp_setpoint);
Serial.print(", ");
Serial.print("heater on?=");
Serial.print(heaterState);
Serial.print(", ");
Serial.print("motor on?=");
Serial.print(motorState);
Serial.print(", ");
Serial.print("button pressed?=");
Serial.print(reading);
Serial.print(", ");
Serial.print("heater timeout?=");
Serial.print(heater_timeout);
Serial.print(", cooldown start=");
Serial.println(cooldown_start_millis / 1000);
lcd.clear();
lcd.print("tr=");
lcd.print(" ");
lcd.print("h=");
lcd.print(heaterState);
lcd.print("ts=");
lcd.print(temp_setpoint);
lcd.print("temp=");
lcd.print(inside_temp);
lcd.print(" ");
lcd.print("moist=");
lcd.print(inside_moisture);
