[Solved] DHT22 2 (two) decimals
I am new to particle, but i have few panstam running with DHT22.
I have wired DHT22 to Particle on D1 and set up the following code (below), but I am getting only whole rounded number readings. Why is that? I know from my other project that the DHT22 can deliver also 2 decimals. Can you please help me with the required changes in the code?
My code so far:
#include <PietteTech_DHT.h>
// DHT parameters
#define DHTTYPE  DHT22              // Sensor type DHT11/21/22/AM2301/AM2302
#define DHTPIN   D1         	      // Digital pin for communications
#define DHT_SAMPLE_INTERVAL   2000  // Sample every two seconds
// Variables
int temperature;
int humidity;
int blue = D7;
// Declaration
void dht_wrapper();
// Lib Initialize
PietteTech_DHT DHT(DHTPIN, DHTTYPE, dht_wrapper);
UDP Udp;
// globals
unsigned int DHTnextSampleTime; // Next time we want to start sample
unsigned int localPort = 8888;  //
IPAddress remoteIP(192,168,8,194);
int port_temp = 5555;
int port_hum = 6666;
bool bDHTstarted;		            // flag to indicate we started acquisition
int n;                          // counter
    pinMode(blue, OUTPUT);
    DHTnextSampleTime = 0;
    Udp.begin(localPort);
    Serial.println(WiFi.localIP());
void dht_wrapper() {
    DHT.isrCallback();
  // Check if we need to start the next sample
  if (millis() > DHTnextSampleTime) {
	if (!bDHTstarted) {		// start the sample
	    DHT.acquire();
	    bDHTstarted = true;
    if (!DHT.acquiring()) {		// has sample completed?
    // get DHT status
    int result = DHT.getStatus();
    int humidity = DHT.getHumidity();
    int tempf = DHT.getFahrenheit();
    int tempc = DHT.getCelsius();
    int tempk = DHT.getKelvin();
    int dp = DHT.getDewPoint();
    int dpslow = DHT.getDewPointSlow();
    //Turn the built in LED on to indicate publishing
    digitalWrite(blue, HIGH);
    //* Publish readings - uncomment/comment the values you'd like to publish
    Particle.publish("Humidity", String(humidity) + "%");
    //Particle.publish("Temperature", String(tempf) + " °F");
    Particle.publish("Temperature", String(tempc) + " °C");
    //Particle.publish("Temperature", String(tempk) + " °K");
    //Particle.publish("Dew Point", String(dp) + " %");
    //Particle.publish("Dew Point", String(dpslow) + " %");
    // send the UDP Packet
    Udp.beginPacket(remoteIP, port_temp);
    Udp.write(String(tempc));
    Udp.endPacket();
    Udp.beginPacket(remoteIP, port_hum);
    Udp.write(String(humidity));
    Udp.endPacket();
    //Turn the built in LED off indicate publishing finished
    delay(250);
    digitalWrite(blue, LOW);
    n++;  // increment counter
    bDHTstarted = false;  // reset the sample flag so we can take another
    DHTnextSampleTime = millis() + DHT_SAMPLE_INTERVAL;  // set the time for next sample
Thank you! :slight_smile:
@TiBee, declare your variables as floats! The PietteTech_DHT library returns floats :wink:
just by changing to :
// get DHT status
float result = DHT.getStatus();
float humidity = DHT.getHumidity();
float tempf = DHT.getFahrenheit();
float tempc = DHT.getTemperature();
float tempk = DHT.getKelvin();
float dp = DHT.getDewPoint();
float dpslow = DHT.getDewPointSlow();
does nothing :confused:
there is a similar sniplet @ https://github.com/simonmonk/tab_arduino/blob/master/ch_19_network_sensors/ch_19_network_sensors.ino
… so it should work?!
Thank you!
@TiBee, why don’t you start with an example from the PietteTech_DHT library (eg. DHT_example.ino) to be sure everything is working first.
@peekay123 the issue was not in the code but is in the cloud flashing process… somehow the code is not being transferred from the cloud down to earth (particle). Particle blinks, that it is receiving something, restarts, but continues with the old firmware.
So I compiled the Fw, downloaded it and flashed with CLI, and now it works…
Thank you for the hint with the Floating. I am not that good in coding :slight_smile:
Code :
// DHT parameters
// Variables
int blue = D7;
// Declaration
void dht_wrapper();
// Lib Initialize
UDP Udp;
// globals
int port_temp = 5000;
int port_hum = 5001;
int n;                          // counter
    DHT.isrCallback();
	    DHT.acquire();
	    bDHTstarted = true;
    // get DHT status
    float tempc = DHT.readTemperature();
    Udp.endPacket();
    Udp.endPacket();
    delay(250);
