Solar Power Photon
Folks,
I live int he UK (Read not alot of Sun) I have a power Shield with a LIPo Battery but i would like to charge it with a solar pannel. Can anyone recommend a Cheap/Simple way of doing this?
@mrclj - Solar Powered Core
This is one that I have living on my windowsil now for +3 years (and I’ve never plugged it in to power). It seems perfectly happy living there and I think the battery gets down to 85% charge overnight.
I do live in South Africa (read plenty of sun) so perhaps a slightly larger panel for yours should be fine?
Let me know if you have any questions… Neal.
Here is my setup.
I would recommend some solar panels by Voltaic Systems.
Also below is my latest code for running off solar power and pushing data to Ubidots. You can easily add code to Particle Publish if that's how you want to send data.
SYSTEM_MODE(SEMI_AUTOMATIC);
//SYSTEM_THREAD(ENABLED);
#include "Ubidots/Ubidots.h"
#define TOKEN "password_goes_here"  // Put here your Ubidots TOKEN
#define DATA_SOURCE_NAME "ElectronSleepNew"
SerialLogHandler logHandler(LOG_LEVEL_ALL);  //This serial prints system process via USB incase you need to debug any problems you may be having with the system.
Ubidots ubidots(TOKEN); // A data source with particle name will be created in your Ubidots account.
int button = D0;         // Connect a Button to Pin D0 to Wake the Electron when in System Sleep mode.
int ledPin = D7;         // LED connected to D1
int sleepInterval = 60;  // This is used below for sleep times and is equal to 60 seconds of time.
ApplicationWatchdog wd(660000, System.reset); //This Watchdog code will reset the processor if the dog is not kicked every 11 mins which gives time for 2 modem reset's.
 //Serial.begin(115200);
 pinMode(button, INPUT_PULLDOWN);  // Sets pin as input
 pinMode(ledPin, OUTPUT);          // Sets pin as output
 ubidots.setDatasourceName(DATA_SOURCE_NAME); //This name will automatically show up in Ubidots the first time you post data.
 PMIC pmic; //Initalize the PMIC class so you can call the Power Management functions below.
 pmic.setChargeCurrent(0,0,1,0,0,0); //Set charging current to 1024mA (512 + 512 offset)
 pmic.setInputVoltageLimit(4840);   //Set the lowest input voltage to 4.84 volts. This keeps my 5v solar panel from operating below 4.84 volts.
FuelGauge fuel; // Initalize the Fuel Gauge so we can call the fuel gauge functions below.
if(fuel.getSoC() > 20) // If the battery SOC is above 20% then we will turn on the modem and then send the sensor data.
   float value1 = fuel.getVCell();
   float value2 = fuel.getSoC();
  ubidots.add("Volts", value1);  // Change for your variable name
  ubidots.add("SOC", value2);
  Cellular.connect();  // This command turns on the Cellular Modem and tells it to connect to the cellular network.
   if (!waitFor(Cellular.ready, 600000)) { //If the cellular modem does not successfuly connect to the cellular network in 10 mins then go back to sleep via the sleep command below. After 5 mins of not successfuly connecting the modem will reset.
    System.sleep(D0, RISING,sleepInterval * 2, SLEEP_NETWORK_STANDBY); //Put the Electron into Sleep Mode for 2 Mins + leave the Modem in Sleep Standby mode so when you wake up the modem is ready to send data vs a full reconnection process.
     ubidots.sendAll(); // Send fuel gauge data to your Ubidots account.
     digitalWrite(ledPin, HIGH);   // Sets the LED on
     delay(250);                   // waits for a second
     digitalWrite(ledPin, LOW);    // Sets the LED off
  else //If the battery SOC is below 20% then we will flash the LED 4 times so we know. Then put the device into deep sleep for 1 hour and check SOC again.
  //The 6 lines of code below are needed to turn off the Modem before sleeping if your using SYSTEM_THREAD(ENABLED); with the current 0.6.0 firmware. It's a AT Command problem currently.
  //Cellular.on();
  //delay(10000);
  //Cellular.command("AT+CPWROFF\r\n");
  //delay(2000);
  //FuelGauge().sleep();
  //delay(2000);
  delay(150);                   // Waits for a second
  System.sleep(SLEEP_MODE_DEEP, 3600);  //Put the Electron into Deep Sleep for 1 Hour.
