Several beginner programming questions about RFID reader code
The controller may not matter for your final setup but for the port of the library it may well do.
In this community we discuss, port and maintain libraries that (should) run on the Particle devices but not any arbitrary non-related library for other controllers.
If you are running a Particle device and have problems with the libraries that are meant to run then we probably can help, but with your code I’m not really familiar or would even know where to look into the implementation of the libraries you are calling there.
Nor do I know how the “SPI concept” is implemented on your PIC. Although I could look it up. But a dedicated PIC community (if there is any) or any cross platform forum (e.g. stackexchange) would probably already have people who know.
Thanks for your kind information.
SPI communication is working fine, already I have tested SPI comm alone thru master & slave so I feel, PIC controller’s SPI code not a problem.
Below URL code only I have implemented,
If you have any idea kindly assist me.
Thank you.
