Setting keepAlive With SYSTEM_THREAD & 3rd Party SIM
Relevant General Configuration:
  • Electron
  • 3rd Party SIM
  • SYSTEM_THREAD(ENABLED);
When using a 3rd party SIM card with the Electron, the default keepAlive interval needs to be adjusted to a lower value to keep the return connection from the Particle Cloud open. That interval more or less is experimentally determined and will vary depending on the SIM provider but generally ranges from 30 seconds to a few minutes.
When I first started using a 3rd party SIM card in a multi-threaded program I had issues getting the electron to stay connected to the Particle cloud. While I could reliably send data to other servers via my MQTT client, I couldn’t connect to Particle. Here is an example of code that does NOT work properly, at least in my testing:
// electron-hardware-test.ino
// THIS DOES NOT WORK
STARTUP(cellular_credentials_set("hologram", "", "", NULL));
    Particle.keepAlive(30);
Based on this thread I had expected that putting the keepAlive call in the setup function would work, but I found this to not be reliably true for me. Even when setting keepAlive to 30 seconds (which is as low as it should need to be) I would disconnect after my SIM provider’s timeout period of approx 120seconds. This made me think that keepAlive wasn’t getting properly set.
I found the solution for me to be moving the keepAlive call into the main loop, and only calling it once Particle finished connecting to the cloud for the first time (essentially emulating the networking state flow of single threaded operation where setup waits for the cloud connection). The following code has seemed to work reliably for me:
// THIS DOES WORK
bool keepAlive_set = false;
    if (!keepAlive_set && Particle.connected())
        keepAlive_set = true;
I found this workaround to be non-intuitive and underdocumented. I would suggest a slight documentation update to indicate what the requirement is for keepAlive to be properly set in the context of SYSTEM_THREAD (which I’m assuming is initial cloud connectivity). Alternatively, ideally if there was some way to ensure that value got set regardless of when it was called that would be more intuitive. I hope this is helpful for anyone else trying to use a 3rd party SIM in threaded mode.
@justicefreed_amper thanks for the clear post on the issue. This is a documented bug and your workaround is perfect.
Frustratingly, this known bug is still not described in the docs. The result was a day lost independently rediscovering it. It’s been four months since this was first documented on GitHub, what is a reasonable amount of time to expect to have to wait before it is documented at https://docs.particle.io/reference/firmware/electron/#particle-keepalive-?
Odd maths - today April 5th - GitHub Jan 27th suggest 2.5 months give or take :wink:
BTW, if you check the times between firmware releases and the backlog of other issues, you may need to allow for some time to address all filed issues.
Just as the firmware also the docs are open source, so updates and PRs are welcome.
Fair, I’m counting Jan/Feb/Mar/Apr as spanning four months, but you’re absolutely right it’s closer to 75 days than 120. Neither seems like a good target for documenting a workaround. (But completely understood that a good target for a firmware fix is substantially different because it needs to be sequenced into existing priorities.)
Good docs are hard. Speaking from experience from open-source autopilots, the best open- and closed-source communities have a doc manager whose job is to assertively update docs as a function of discovered and patched bugs. The Electron is, after all, a product which our company is paying for and integrating into our product line. There’s only so much of a professional product’s maintenance which can be offloaded to us, its clients.
On a personal level, I’m happy to contribute to being the first to discover a bug. Our contribution to open source is to be a willing participant with Particle to track down, isolate, and thoroughly document bugs. After that, I’m not happy when several people before us have had the same issue and it hasn’t been pushed to the doc manager’s attention.
That's why Particle has recentyl hired such an individual :wink:
