Would you mind using this example for your java code: (from: http://www.tutorialspoint.com/java/java_networking.htm)
// File Name GreetingServer.java
import java.net.*;
import java.io.*;
public class GreetingServer extends Thread
private ServerSocket serverSocket;
public GreetingServer(int port) throws IOException
serverSocket = new ServerSocket(port);
serverSocket.setSoTimeout(10000);
public void run()
while(true)
try
System.out.println("Waiting for client on port " +
serverSocket.getLocalPort() + "...");
Socket server = serverSocket.accept();
System.out.println("Just connected to "
+ server.getRemoteSocketAddress());
DataInputStream in =
new DataInputStream(server.getInputStream());
System.out.println(in.readUTF());
DataOutputStream out =
new DataOutputStream(server.getOutputStream());
out.writeUTF("Thank you for connecting to "
+ server.getLocalSocketAddress() + "\nGoodbye!");
server.close();
}catch(SocketTimeoutException s)
System.out.println("Socket timed out!");
break;
}catch(IOException e)
e.printStackTrace();
break;
public static void main(String [] args)
int port = 6000;
try
Thread t = new GreetingServer(port);
t.start();
That should setup a Java Server on Port 6000. Run the server code. It should wait for incoming connection. Next flash your SparkCore will the following code (modify the IP for you server’s ip)
// SYNTAX
TCPClient client;
// EXAMPLE USAGE
TCPClient client;
byte server[] = { 74, 125, 224, 72 }; // PUT YOUR SERVER'S IP HERE!
void setup()
// Make sure your Serial Terminal app is closed before powering your Core
Serial.begin(9600);
// Now open your Serial Terminal, and hit any key to continue!
while(!Serial.available()) SPARK_WLAN_Loop();
Serial.println("connecting...");
if (client.connect(server, 6000))
Serial.println("connected");
client.println("Hello from the SparkCore!");
else
Serial.println("connection failed");
void loop()
if (client.available())
char c = client.read();
Serial.print(c);
if (!client.connected())
Serial.println();
Serial.println("disconnecting.");
client.stop();
for(;;) SPARK_WLAN_Loop();
Open up the serial console on you computer and connect to your SparkCore. Press anykey and look for output.
Let me know if you have any issues.
