Ahh i see! So far no crash with a single subscribe used. Currently im trying to implement MQTT pub/sub to replace particle pub/sub but im facing issues connecting my localhost.
It doesnt connect to 127.0.0.1;1883 !
How do I connect to localhost?
127.0.0.1 would refer to the Photon itself
Your local MQTT broker has probably a 192.168.x.y or 10.0.0.x address which you should either get from the device running the broker or your router.
Hi ScruffR, thanks! I managed to get MQTT to work using wifi hotspot. I also tidied up mode of my code using timers. I forgot to mention that I’m also sending data from particle.variable(ldr/temp/pressure) to HTML file.
Update: I commented away timer4.start() yet the red SOS continues, I suspect the timer time length is causing this …
Q1. Should I run the auto crash detection and debug to fix the SOS?
Q2. Should I sync the timer time length on Device1 Timer3&4 same as Device2 Timer1&2? I’m not sure if I’m using timer correctly in both device codes.
Q3. I put my particle sub/pub handlers into timers hoping it would fix the red SOS since i expected timers to work in a sequential manner.
Example:
Timer timer1(1000L, pub_ambience_status);
Timer timer2(5000L, blynkLDRdata);
Timer timer3(5000L, subTemp);
Timer timer4(1000L, subPress);
void setup(){
timer1.start();
timer2.start();
timer3.start();
timer4.start();
timer1 (1s) → timer2 (5s) → timer3 (5s) → timer4 (1s) and repeat again
(timer1) (timer2) (timer3) (timer4)
0-------------1---------------6---------------11------------12
12-----------13--------------18-------------23------------24
<Device 1 Code>
#include <DailyTimerSpark.h>
#include <blynk.h>
char auth[] = "HIDE";
int led3=D0; // Blynk Nightlight Control + HTML Nightlight Toggle On/Off
int led3_status=-1; // HTML Nightlight Toggle On/Off
int ldr=A0; // Blynk Ambience Brightness
int ldr_status=0; // Blynk Ambience Brightness
int ldranalogvalue=0; // Blynk Ambience Brightness Gauge
WidgetLCD lcd(V1); // Blynk LCD (Date Day Greeting)
WidgetLCD lcd2(V3);
// Check ambience status every 30s
// Blynk LDR Gauge
// iot_C8 MQTT sub to temp and pressure data vals from D8 published temp and pressure readings
void pub_ambience_status(){
ldr_status = analogRead(ldr);
Serial.println("Ambience Change");
Serial.printlnf("LDR Status = %d", ldr_status);
if (ldr_status <= 100){ // Modify this in class
Particle.publish("ambience_C8", "Dark", PRIVATE);
Serial.println("Ambience Status= Dark");
Serial.println("Ambience Dark Request triggered");
else if (ldr_status >= 300){
Particle.publish("ambience_C8", "Bright", PRIVATE);
Serial.println("Ambience Status= Bright");
Serial.println("Ambience Bright Request triggered");
else{
Particle.publish("ambience_C8", "Dim", PUBLIC);
Serial.println("Ambience Status= Dim");
Serial.println("Ambience Dim Request triggered");
void blynkLDRdata(){
Blynk.virtualWrite(V0, ldr_status);
void subTemp(){
Particle.subscribe("temperature_D8", myTempHandler, MY_DEVICES);
// Get Temperature data from subscribed topic and print on LCD
void myTempHandler(const char *event, const char *data){
double temp_val = atof(data);
Serial.printlnf("Temperature Handler executed, %f°C", temp_val);
char msg[32];
snprintf(msg, sizeof(msg), "%.2f°C %s", temp_val, (temp_val > 32.50) ? "Warm" : "Cool");
lcd2.print(0, 0, msg);
void subPress(){
Particle.subscribe("pressure_D8", myPressHandler, MY_DEVICES);
void myPressHandler(const char *event, const char *data){
double press_val = atof(data);
Serial.printlnf("Pressure Handler executed, %fPa", press_val);
char msg[32];
snprintf(msg, sizeof(msg), "%dPa %s", press_val, (press_val > 900) ? "High" : "Low");
void setup(){
// bLYNK LCD Time Display (Set Timezone to SG using +8)
Time.zone(+8);
// Nightlight Toggle On/Off
pinMode(led3, OUTPUT);
Particle.function("led",ledToggle);
// HTML Ambience Brightness Gauge
ldr_status=analogRead(ldr);
Particle.variable("ldranalogvalue", ldr_status);
while (!Serial);
Serial.println("Serial is Running");
Blynk.begin(auth);
timer1.start();
timer2.start();
timer3.start();
timer4.start();
void loop(){
Blynk.run();
// Blynk LCD Display (Date + Greeting)
DisplayTime();
MorningDisplay();
AfternoonDisplay();
int ledToggle(String command) {
if (command=="on") {
digitalWrite(led3,HIGH);
Serial.print("HTML led3 ");
Serial.println(command);
return 1;
else if (command=="off") {
digitalWrite(led3,LOW);
return 0;
else if (command=="read") {
return digitalRead(led3);
else {
return -1;
void DisplayTime(){
lcd.print(0,0, (const char*)Time.format("%I:%M%p"));
lcd.print(0,1, (const char*)Time.format("%a %e %b"));
delay(1000);
void MorningDisplay(){
DailyTimer MorningTimer(6, 0, 11, 59, EVERY_DAY); // Fixed start time and end time
if(MorningTimer.startTrigger()){
lcd.print(0,1, "Good Morning!");
delay(2000);
MorningMsg();
delay(1000);
void AfternoonDisplay(){
DailyTimer AfternoonTimer(12, 0, 17, 59, EVERY_DAY); // Fixed start time and end time
if(AfternoonTimer.startTrigger()){
lcd.print(0,1, "Good Afternoon! ");
delay(1000);
AfternoonMsg();
delay(1000);
void MorningMsg(){
String text = "Time for Breakfast";
int space=(strlen(text)-15); // Set no. of space for text to move
for(int start=0; start<space; start++){ // Increment loop
lcd.print(0,1, text.substring(start)); // substring func remove char of string via loop and prints continuously
delay(1000);
void AfternoonMsg(){
String text = "Lunch Break "; // Spaces to avoid other text from overlapping
lcd.print(0,1, text);
delay(1000);
<Device 2 Code>
#include <Adafruit_BMP280.h>
#include <blynk.h>
Adafruit_BMP280 bmp;
double env_temp;
double env_Pressure;
// HTML Temp + Press Gage Data
double temp_reading;
double press_reading;
// Blynk Slider + Button
int led1 = D2;
Timer timer1(5000L, pubTemp);
Timer timer2(10000L, pubPress);
// iot_D8 Device MQTT subscribe to Ambience_C8
Timer timer3(10000L, subAmbience);
void pubTemp(){
double t_temp = bmp.readTemperature();
Serial.println("Temperature Request triggered");
Particle.publish("temperature_D8", String(t_temp), PRIVATE);
void pubPress(){
double t_Pressure = bmp.readPressure();
Serial.println("Pressure Request triggered");
Particle.publish("pressure_D8", String(t_Pressure), PRIVATE);
void subAmbience(){
Particle.subscribe("ambience_C8", myAmbienceHandler, MY_DEVICES);
// Get data from subscribed topic ambience_C8, on / off led according to ambience status
void myAmbienceHandler(const char *event, const char *data){
String ambience_status = String(data);
Serial.println("Ambience Handler executed");
Serial.println(ambience_status);
if(ambience_status == "Dark"){
digitalWrite(D2, HIGH);
Serial.println("Led turns on");
else if(ambience_status == "Bright"){
digitalWrite(D2, LOW);
Serial.println("Led stays off");
else if(ambience_status == "Dim"){
pinMode(led1, OUTPUT);
// HTML Temp and pressure gauge reading
Particle.variable("temp", temp_reading);
Particle.variable("press", press_reading);
Blynk.begin(auth);
while (!Serial);
if (!bmp.begin()){
Serial.println("Can't find the sensor BMP280");
timer1.start();
timer2.start();
timer3.start();
Blynk.run();
temp_reading = bmp.readTemperature();
press_reading = bmp.readPressure();
I doubt that. It's usually not helpful to jump to conclusions before having evidence for it.
So yes to Q1.
Q2 is a non-issue IMO although having multiple timers with the same cadence would rather suggest to do all the stuff in the same timer (if it has to be via timer at all is open for discussion).
For Q3, no. your 1sec timers will fire 5 times in 5 seconds while your 5sec timers will fire only once. And in the long run you should not rely on the order of execution at all.
When using timers you need to be aware that the thread running these timers only has a very limited stack space and hence any heavy library calls (i.e. Blynk) may run the risk of overflowing the stack.
Typically when you get an SOS crash you also get a number of slow blinks after the first set of SOS blinks. The number of these blinks tells you more about the type of crash.
If this is indeed a stack issue you'd see SOS+13.
For that it's always good to also provide that information as early as possible in a discussion like this.
https://docs.particle.io/tutorials/device-os/led/photon/#red-flash-sos
While Software Timers are a great tool for some things, they are not suitable for everything and in your case I don't see good reason for them.
I'd guess your initial SOS crash was of a different kind. That also shows that it is not advisable to considerably change code you still haven't fully debugged.
Adding new features (in this case Software Timers) may well introduce new problems of its own and makes debugging much harder (is it still the old problem or a new one or a combination of the two).
BTW, why on earth have you got subTemp(), subPress() and subAmbience timers that keep subscribing to the same events over and over every few seconds?
About this
Since programming is a matter where preciseness is key I also want to be precise when describing things verbally ![]()
Particle.variable()s are requested not sent.
With new code here, I’ve bottled down the two issues of red SOS.
Device 1 updated code has the following:
Timer 1 - publishes ambience_c8, no subscribes are inside.
Timer 2 - publishes ldrdata to blynk (This causes red SOS) [I couldnt get blynktimer timer; to work thus i used software timer], remove timer 2 and device works fine
Prints displaytime and message function to blynk widget lcd(v1) via lcd.print.
Device 2 updated code has the following:
Timer 1 - publishes temp
Timer 2 - publishes pressure
Subscribes to temp, pressure and ambience_c8 (This causes panic, hard_fault, not sure what this is though still flash red)
Prints temp and pressure to blynk widget lcd2(V3) via lcd2.print
I understand that IoT integration with blynk and particle requires the void loop to be as clean as possible containing only
blynk.run() and timer.run().
Q3. In device1 code, I know the displaytime() with delay(1000) and displaymorningmsg() in void loop causes the blynk app connection instability, however I have no idea how to change the code. If i put these two functions in void setup, then only displaytime() lcd.print(0,1) will display.
Q4. Now I know that int (32bit int) vs long int (64bit int), I will remove the L from all my timers.
<Device 1 code>
#include <blynk.h>
char auth[] = "HIDDEN";
WidgetLCD lcd2(V3);
// Check ambience status every 1min
Timer timer1(60000, pub_ambience_status);
// Blynk LDR Gauge
Timer timer2(1000, blynkLDRdata);
if(analogRead(ldr) >= (ldr_status+30) || analogRead(ldr) <= (ldr_status-30)) //50
else{
char msg[32];
char msg[32];
lcd2.print(0, 1, msg);
void setup(){
DisplayTime();
MorningDisplay();
ldr_status=analogRead(ldr); // pinMode not needed since analogRead used
Blynk.begin(auth);
Time.zone(+8);
// IP ADDRESS
//Particle.subscribe("temperature_D8", myTempHandler, MY_DEVICES);
//Particle.subscribe("pressure_D8", myPressHandler, MY_DEVICES);
while (!Serial);
Serial.println("Blynk is running. Ensure wifi connected on device and app are same");
timer1.start();
//timer2.start();
void loop(){
// Run Blynk App
Blynk.run();
// Blynk LDR Gauge
//Blynk.virtualWrite(V0, ldr_status);
//DisplayTime();
//MorningDisplay();
return 1;
return 0;
else {
return -1;
void DisplayTime(){
lcd.print(0,1, (const char*)Time.format("%a %e %b "));
delay(2000);
<Device 2 code>
#include <blynk.h>
Adafruit_BMP280 bmp; // I2C
WidgetLCD lcd2(V3);
double env_temp;
int led1 = D2;
Timer timer1(5000, pubTemp);
Timer timer2(20000, pubPress);
char msg[32];
Serial.printlnf("Pressure Handler executed, %.2fPa", press_val);
char msg[32];
snprintf(msg, sizeof(msg), "%.2fPa %s", press_val, (press_val > 900) ? "High" : "Low");
void pubTemp(){
void pubPress(){
Blynk.begin(auth);
while (!Serial);
if (!bmp.begin()){
timer1.start();
timer2.start();
Blynk.run();
Update 2:
Now I've made some changes to both device codes. I'm only getting red SOS on device 1 (13 blinks ) when I use timer2.start().
Not sure why the hard_fault error earlier is gone but i guess thats a good sign!
Device 1 code:
Device 2 code
<Device 1 code>
#include <blynk.h>
WidgetLCD lcd2(V3);
// Blynk LDR Gauge
Timer timer2(60000, blynkLDRdata);
else{
char msg[32];
char msg[32];
void setup(){
DisplayTime();
MorningDisplay();
Blynk.begin(auth);
Time.zone(+8);
// IP ADDRESS
while (!Serial);
timer1.start();
//timer2.start();
void loop(){
// Run Blynk App
Blynk.run();
// Blynk LDR Gauge
//DisplayTime();
//MorningDisplay();
return 1;
return 0;
else {
return -1;
void DisplayTime(){
delay(2000);
<Device 2 code >
#include <blynk.h>
WidgetLCD lcd2(V3);
double env_temp;
int led1 = D2;
void pubTemp(){
void pubPress(){
char msg[32];
char msg[32];
Blynk.begin(auth);
while (!Serial);
if (!bmp.begin()){
timer1.start();
timer2.start();
Blynk.run();
"Panic crash" is the umbrella term for all SOS+x errors and "stack overflow" (SOS+13) is one of them.
While this isn't really a question, that's what I was referring to with this
Hmm, how come? I provided you with a link that would have clarified that and also listed some common causes ![]()
This is a very simplistic view. You can still keep loop() clean and tidy even with doing other stuff therein. You just need to avoid anything that may bog down the code flow for extended periods (e.g. delay(), tight loops, ...).
One way to do that is by conciously using timers (i.e. one-shot timers) or a dedicated "soft delay" function that keeps your essential tasks running while waiting.
e.g.
bool ldrNeedUpdate = false;
ldrNeedUpdate = true;
// cannot be called from a Software Timer!
void mustDo() {
if (Particle.connected()) {
Blynk.run(); // not Blynk.loop();
timer.run(); // not Blynk.timer();
if (ldrNeedUpdate) {
Particle.process();
void softDelay(uint32_t timeout) {
for (uint32_t ms = millis(); millis() - ms < timeout; mustDo());
mustDo();
Whenever you need a delay all the essential stuff will still be executed while waiting.
Alternatively I'd even consider using an FSM for the display which would be called in the mustDo() function and can be controlled from your other code - including timers.
I'd also not read the BMP sensor on each iteration of loop(), particularly when only using the readings every few seconds.
BTW, Blynk timers are nothing else than "obscured" a millis() timers.
Hi ScruffR! I noticed that the red SOS would appear when my device1 timer1 (pub_ambience) duration is set to 3 seconds. However at 30seconds or 60seconds, the red SOS does not appear.
Q5. I was wondering if using switch-case would work with timers than compared to if-elseif-else statement.
I tried your example code but Blynk.loop() and Blynk.timer() gives blynkparticle does not contain member loop/timer! I commented them out and pasted the code, the ldr value wasnt updated
Also, how do I set the timeout or softdelay duration?
Despite that, I was able to use BlynkTimer timer; to update ldr value in blynk app and also displaytime.
BlynkTimer timer;
void setup(){
timer.setInterval(3000, ldrData);
void ldrData(){
DisplayTime();
void loop(){
timer.run();
Q6. What can I use to replace the delay function which will not interrupt blynk.run in void loop since I want to display the day + date for two seconds, followed by a greeting message (e.g good morning) for two seconds and repeat this cycle.
Meanwhile, im doing some reading up on one shot timers and soft delays here...
Update 2:
For device 1, Instead of using software timer to publish this value, I decided to use the BlynkTimer timer; and place my if-elseif-else statement + publish ambience value. However, the Red SOS occurs after 3minutes of running the code and connects back to cloud.
Q7. How should I optimize this?
Q8. I plan put temp and pressure publish and reading in BlynkTimer timer; as well, do you recommend this?
Device 1 Code
#include <blynk.h>
BlynkTimer timer;
WidgetLCD lcd2(V3); // Blynk LCD (Temp + Pressure)
// Check ambience status every 30 seconds
/*Timer timer1(30000, pub_ambience_status);
else{
char msg[32];
char msg[32];
void setup(){
//MorningDisplay();
Blynk.begin(auth);
Time.zone(+8);
lcd.clear();
lcd2.clear();
// IP ADDRESS
while (!Serial);
//timer1.start();
// Push ldrdata into blynk app every 3 seconds (Prevents floodings)
timer.setInterval(3000, ambience_status);
void ambience_status(){
// update ldr_value to gauge
// Publish ambience_status
lcd.print(9,0, "Dark ");
lcd.print(9,0, "Bright");
else{
lcd.print(9,0, "Dim ");
Particle.publish("ambience_C8", "Dim", PRIVATE);
DisplayTime();
DisplayDate();
void loop(){
Blynk.run();
timer.run();
void DisplayTime(){
void DisplayDate(){
return 1;
return 0;
else {
return -1;
Device 2 Code
#include <blynk.h>
WidgetLCD lcd2(V3);
double env_temp;
int led1 = D2;
// Publish temp val every 5s
// Publish press val every 20s
void pubTemp(){
void pubPress(){
char msg[32];
char msg[32];
Blynk.begin(auth);
while (!Serial);
if (!bmp.begin()){
timer1.start();
timer2.start();
Blynk.run();
switch-case is a common C concept and works irrespective of location. The only thing to consider that it can only work on ordinal values (not strings nor floating point values).
My bad, it should obviously be Blynk.run() instead of Blynk.loop() (corrected above) and Blynk.timer() should rather be timer.run() ![]()
Just as you would with delay() pass the desired time as parameter softDelay(1000).
That is what softDelay() would do. In both cases - when running loop() or stuck inside softDelay() the important stuff will be attended to via the mustDo() calls.
Hi ScruffR! Thanks for your advice! I put my particle.publish inside the Mustdo() function using a couple of if-statements to replace use of software timer and also iterate through bmp.reading in mustDo function as well!
Q1. I have a physical button and widget button. I am able to code the physical button to publish data when pressed. However, I cant seem to sync widget button state to physical button.
I want both widget button and physical button to publish data when pressed. How can I achieve this?
I tried this method to read state of button V4:
BLYNK_READ(V4){
if(BLYNK_READ(V4)==HIGH){
Particle.publish("door_status_D8", "door locked");
else{
Particle.publish("door_status_D8", "DOOR UNLOCKED");
Q2. Now that most of my code is inside the mustDo() function and use of softdelays in void loop, the red SOS is gone! but… im getting red SOS when Im trying to write code for blynk.email widget to send an email when particle.subscribe door handler receives “door unlocked” but I cant get the email to send through
Am I using blynk.email widget correctly?
void myDoorHandler(const char *event, const char *data){
String door_status = String(data);
Serial.println("Door Handler executed");
Serial.println(door_status);
if(door_status == "DOOR UNLOCKED"){
String msg = "Your door was UNLOCKED on "+Time.format("%a %e %b")+" at "+Time.format("%I:%M%p.")+"Please ignore this email if this was you.";
lcd3.print(0, 0, "Door UNLOCKED!");
Serial.println(msg);
Blynk.email("SECURITY ALERT!", msg);
Device 1 Code
#include <blynk.h>
BlynkTimer timer;
WidgetLCD lcd(V1); // Blynk LCD (Date Day Greeting + Ambience Status)
WidgetLCD lcd3(V5); // Blynk LCD (Door status)
void mustDo() {
if (Particle.connected()) { //Particle.process() is a blocking call, and blocks for a few milliseconds.
Blynk.run();
timer.run();
Particle.process();
char msg[32];
char msg[32];
else{
lcd3.print(0, 0, "Door locked ");
void setup(){
Blynk.begin(auth);
Time.zone(+8);
lcd.clear();
lcd2.clear();
lcd3.clear();
// IP ADDRESS
Particle.subscribe("door_status_D8", myDoorHandler, MY_DEVICES);
while (!Serial);
timer.setInterval(2000, functions);
void functions(){
blynkLDRdata();
pub_ambience_status();
else{
void loop(){
mustDo();
DisplayTime();
DisplayDate();
softDelay(1500);
Greeting();
softDelay(1500);
void DisplayTime(){
void DisplayDate(){
void Greeting(){
DailyTimer MorningTimer(5, 0, 11, 59, EVERY_DAY);
DailyTimer AfternoonTimer(12, 0, 16, 59, EVERY_DAY);
DailyTimer EveningTimer(17, 0, 19, 59, EVERY_DAY);
DailyTimer NightTimer(20, 0, 23, 59, EVERY_DAY);
lcd.print(0,1, "Good Morning ");
else if(AfternoonTimer.startTrigger()){
lcd.print(0,1, "Good Afternoon");
else if(EveningTimer.startTrigger()){
lcd.print(0,1, "Good Evening ");
else if(NightTimer.startTrigger()){
lcd.print(0,1, "Good Night ");
else{
lcd.print(0,1, "Midnight ");
return 1;
return 0;
else {
return -1;
Device 2 Code
#include <blynk.h>
BlynkTimer timer;
int button=D4; // Fingerprint scanner
double t_temp;
double t_press;
int led1 = D2;
Timer timer1(5000, fingerprint_scanner);
bool tempNeedUpdate = false;
bool pressNeedUpdate = false;
void tempdata(){
tempNeedUpdate = true;
void pressdata(){
pressNeedUpdate = true;
void mustDo() {
Blynk.run();
timer.run();
if (tempNeedUpdate) {
if (pressNeedUpdate) {
t_press = bmp.readPressure();
Particle.publish("pressure_D8", String(t_press), PRIVATE);
Particle.process();
void functions(){
tempdata();
pressdata();
pinMode(button, INPUT_PULLUP);
Particle.variable("temp", t_temp);
Particle.variable("press", t_press);
Blynk.begin(auth);
while (!Serial);
if (!bmp.begin()){
timer1.start();
timer.setInterval(5000, functions);
void loop(){
mustDo();
void fingerprint_scanner(){
if (digitalRead(button) == LOW){
else{
You omitted the info about which kind of SOS it was again!
And you also use String again despite being warned to avoid it wherever possible.
If I'm not mistaken the first parameter of Blynk.email() is supposed to be the email address, isn't it? But you are not passing a valid email address there.
Not sure what the current state of your project is, but here I have tried to do the same thing entirely without timers and delays. Also unifying functions that mainly do the same thing into only one.
Particle Web IDE
The code for both device types is all there in that one file. You only need to set the target type in the first line
// either
#define DEVICE_TYPE 1
// or
#define DEVICE_TYPE 2
Hi ScruffR! Thank you very much for your writing the code. I've tested it and I have no stack overflow, i will try to implement parts of it (unifying function and publish) into my code
I just realised i used strings in my ambience handler!! I noticed in your code you wrote the below.
void c8_Handler(const char *event, const char *data){
Log.trace("%s: <%s>", event, data);
if(!LITERALCMP(data, "Dark")) {
I;m trying to understand const and strings. If I replace if(ambience_status=="Dark") with if(data=="Dark"), my code still verified, however whatever is inside the if statement does not execute. I tried if(data = "Dark") and whatever inside the if statement works. Why is this so?
I was wondering if writing serialprint&publish once based on LDR state every 5 seconds would allow photon to be more efficient;
I'm about halfway done with my project, though I'm still facing stack overflow issue with my own code.
I managed to get the fingerprint scanner widget button on blynk working with this:
else{ // HIGH
BLYNK_WRITE(V4){ // widget btn state opposite of physical btn state
if(param.asInt()){ // HIGH , param.asInt() gets value from pin V4
else{ // LOW
const "variables" will only reside in flash and use no RAM. Non-const initialised variables occupy space in both flash and RAM. Since these values will never change while the program is running there is no use in wasting RAM.
Log.xxx() is not only neater but also allows you to disable the logging entirely (and not even be compiled into the code) by simply changing the LOG_LEVEL
A single Particle.publish() instruction makes it easier to (potentially) change the event name and using a common variable to store the data makes reusing that variable for different function calls easier (e.g. logging and publishing and displaying the same text).
Also Particle has removed the possibility to publish PUBLIC events and hence the PRIVATE scope has become redundant.
I also moved the C8_/D8_ qualifyier to the front in order to have one subscribe filter and thus handler catch multiple events of the same type.
Function prototypes are actually a C/C++ requirement but Particle (adopting the Wiring/Arduino ease-of-use paradigm) has opted to have a pre-processor adding prototypes when the user happens to have forgotten to do so.
However, in some circumstances that pre-processor fails to do that perfectly and hence it's best practice to add them manually anyway (in my test at least one function was not prototyped by the pre-processor, so I added prototypes for all functions - if you remove the prototypes you may see the difference).
String is a non-trivial datatype and hence has a somewhat heavier impact on code size and may also cause heap fragmentation due to its dynamic memory needs but offers some layers of comfort using it. However, I usually opt for safer and smaller code even when it means needing to know more about how programming works ![]()
C-strings (i.e. char* and char[]) don't offer the comfort of having an operator==() overload for equality checks hence you need to use strcmp() and relatives instead.
In addition to that I defined a macro (LITERALCMP) which neatly packages strncmp() in a way so that I don't have to write the same literal twice
(programmers are lazy too
The == check didn't fail to compile because it's a perfectly allowed instruction but it doesn't do what you may think it does. It only compares the addresses of the two strings but they will (almost) never be the same even when the string contents are.
This isn't best style tho'
Both functions do mostly the same thing, so that part should go in a dedicated function which can be called from these two.
inline void pubDoorState(bool state) {
Particle.publish("D8_door_status", state ? "door locked" : "DOOR UNLOCKED!");
void fingerprint_scanner() {
pubDoorState(digitalRead(button));
BLYNK_WRITE(V4) {
pubDoorState(param.asInt());
(I also changed the event name for above reason to unify the subscription handler(s) and also added the exclamation mark to the unlocked-message as my subscribe handler looks for it)
BTW, even with the two separate implementations it's poor style to have the same logic flipped between the two. In one you first check for LOW/FALSE/0 and else and in the second you do the opposite HIGH/TRUE/!0 and else. Even when writing code only for yourself try to write it in a way that anybody (including yourself in the far future) will be easily able to comprehend what's going on and functions that do the same should also look the same (which would then make it easy to see that they actually should be the same
Hi ScruffR! Thanks for the detailed explaination!! I never knew about all these !! Interesting and informative!
Update 2 :A lright, I’ll put a function into physical and widget button function. Currently checking my code now since D8_handlers arent working
I’ve re-written my code here
Device 1 Code
#include <blynk.h>
BlynkTimer timer;
SerialLogHandler logHandler(LOG_LEVEL_ERROR, {{"iot_C8", LOG_LEVEL_INFO}});
const int led3=D0; // Blynk Nightlight Control (Slider) + HTML Nightlight Toggle On/Off
const int ldr=A0; // Blynk Ambience Brightness
const char auth[] = "HIDDEN";
void mustDo() {
Blynk.run();
timer.run();
ldrNeedUpdate = false; //Particle.process() is a blocking call, and blocks for a few milliseconds.
Particle.process();
void D8_Handlers(const char *event, const char *data){
char msg[128];
int line = 0;
double val = atof(data);
if(event = "D8_temperature"){
Log.info("Temperature Handler executed, %f°C", val);
snprintf(msg, sizeof(msg), "%.2f°C %s", val, (val > 32.50) ? "Warm" : "Cool");
line = 0;
else if(event = "D8_pressure"){
Log.info("Pressure Handler executed, %.2fPa", val);
snprintf(msg, sizeof(msg), "%.2fPa %s", val, (val > 900) ? "High" : "Low");
line = 1;
else if(event = "D8_door_status"){
Log.info("Door Handler executed: %s", data);
if(data = "DOOR UNLOCKED!") {
snprintf(msg, sizeof(msg), "Your door was UNLOCKED on %s.\r\n"
"Please ignore if this was you."
, (const char*)Time.format("%a %e %b at %I:%M%p"));
Log.info(msg);
Blynk.email("hidden@gmail.com", "SECURITY ALERT!", msg);
lcd3.print(0, 0, data);
else{
Log.warn("Unknown event <%s>", event);
return;
lcd.print(0, line, msg);
void setup(){
Blynk.begin(auth);
Time.zone(+8);
lcd.clear();
lcd2.clear();
lcd3.clear();
// IP ADDRESS
// iot_C8 MQTT sub to door status, temp and pressure data vals from D8 published temp and pressure readings
//Particle.subscribe("D8_door_status", myDoorHandler, MY_DEVICES);
//Particle.subscribe("D8_temperature", myTempHandler, MY_DEVICES);
//Particle.subscribe("D8_pressure", myPressHandler, MY_DEVICES);
Particle.subscribe("D8_Handlers", D8_Handlers, MY_DEVICES);
Log.info("Serial is Running");
void functions(){
blynkLDRdata();
Log.info("Ambience Status= Dark");
Log.info("Ambience Status= Bright");
else{
Log.info("Ambience Status= Dim");
void loop(){
mustDo();
DisplayTime();
DisplayDate();
softDelay(2000);
Greeting();
softDelay(2000);
void DisplayTime(){
void DisplayDate(){
void Greeting(){
float hh = (Time.local() % 86400) / 3600.0; // Current decimal hour of the day , currenthr*24hr/1hr
if (hh < 5.0){
lcd.print(0, 1, "Midnight");
else if (hh < 12.0){
lcd.print(0, 1, "Good Morning");
else if (hh < 17.0){
lcd.print(0, 1, "Good Afternoon");
else if(hh < 20.0){
lcd.print(0, 1, "Good Evening");
else if(hh < 24.0){
lcd.print(0, 1, "Night");
Log.info("HTML led3 on");
return 1;
Log.info("HTML led3 off");
return 0;
else {
return -1;
Device 2 Code
#include <blynk.h>
SerialLogHandler logHandler(LOG_LEVEL_ERROR, {{"iot_D8", LOG_LEVEL_INFO}});
BlynkTimer timer;
const int led1 = D2; // Ambience light
const int button = D4; // Fingerprint scanner
double t_temp;
double t_press;
// Update fingerprint status every 5s
Timer timer1(3000, fingerprint_scanner);
void tempdata(){
void pressdata(){
void mustDo() {
Blynk.run();
timer.run();
char temp_data[16];
snprintf(temp_data, sizeof(temp_data), "%.2f", t_temp);
Particle.publish("D8_temperature", temp_data, PRIVATE);
char press_data[16];
snprintf(press_data, sizeof(press_data), "%.1f", t_press);
Particle.publish("D8_pressure", press_data, PRIVATE);
Particle.process();
void functions(){
tempdata();
pressdata();
if(data = "Dark"){
Log.info("Led turns on");
else if((data = "Bright") || (data = "Dim")){
Log.info("Led stays off");
else{
// nothing
Particle.publish("D8_door_status", "DOOR UNLOCKED");
else{ // HIGH
Particle.publish("D8_door_status", "door locked");
else{ // LOW
Blynk.begin(auth);
timer1.start();
// Update temp and press every 5 seconds
if (!bmp.begin()){
Log.warn("Can't find the sensor BMP280");
void loop(){
mustDo();
static has different meanings between C and C++.
static variables inside functions are still RAM based but will retain their value even after the function has finished.
static class variables are shared between all instances of said class but are also RAM based.
Because you changed the scope for the log handler from app to iot_C8.
But Log.info() logs to the app scope. If you want it to log it the iot_C8 scope you'd need to instantiate a Logger myLog("iot_C8") and use that instead.
There are mulitple issues.
= instead of the equality check ==== as I said earlier const char* cannot be checked for equality that wayLog.trace("%s: <%s>", event, data); at the very top of your handler to see, whether the handler fires at all and what data it receives (will require extenging the scope to LOG_LEVEL_ALL)But foremost this
This will only trigger for events starting with D8_Handlers but the only common part of your events is D8_. That's why my code looks like this
Particle.subscribe("D8_", d8_Handler);
Hi ScruffR! Oh thanks!! I checked out the strcmp() you hyperlinked. Now I understand that it was a const char string instead of normal string!!
