Servo goes to angle, then goes back?
Lacking a potentiometer to set the angles of my servos (case is limiting movements), I decided to build a function, and then just pass values, and see how far the limits are.
All is good, I pass the function, and the servo moves. But 1 mili second later, the servo goes back to the initial position?
I dont see it in the code anywhere, yet it does this persistently.
How does the servo stay in the angle passed in the function?
Here's the code. I used the function example from the docs:
#include <HC_SR04.h>
int brewCoffee(String command);
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int distance = 0;
int percentage,heightTank, deviation;
int angle;
double cm = 0.0;
int trigPin = D4;
int echoPin = D5;
HC_SR04 rangefinder = HC_SR04(trigPin, echoPin);
    myservo.attach(D0);  // attaches the servo on pin 0 to the servo object
    //pinMode(D7, OUTPUT);
    Particle.function("brew", brewCoffee);
    //myservo.write(pos);              // tell servo to go to position in variable 'pos'
    cm = rangefinder.getDistanceCM();
    Serial.printf("Distance: %.2f cm\n", cm);
    angle = (int) cm;
    myservo.write(angle);
    //// Uncomment for extra experiment with Distance sensor
    //setRemoteServo(cm);
    delay(850);
  // look for the matching argument "coffee" <-- max of 64 characters long
    int angle = atoi(command);
    //return 1;
Then I call the function as:
particle call XYZ brew 90
Ideas?
In the loop function, which will be executed every 0.85 seconds because of your delay, you re-write the servo angle to the distance in CM that your rangefinder is reporting. That seems a strange thing to do, to set an angle (units in degrees) to a distance (units in centimeters). But anyway, that's the line that is reseting your servo position.
ps. careful running a servo into its limits. Some servos will protect against damage, and some will not. You could damage the electronics and/or the physical gears.
Aaah, coffee hasnt kicked in yet! Thank you so much for your good eyes :slight_smile:
I reused the code from a previous file. It would turn the servo depending on the distance from the ultrasonic. Makes if fun for the kids, plus you can sort of build a ramp for toy cars, that auto opens when the car is close enough :slight_smile:
Sounds fun!
