Serial communication between Spark and Other
I have a Spark that is driving a LCD. I want to connect it via Serial to a RFduino to access a series of sensor values. However, The RFduino will only have new sensor values maybe every 1 minute or so. Both boards will be busy doing other tasks. How would I set this up? Would Spark Poll Rfduino every minute OR RFduino send something when ready? I am not very familiar with interrupts etc so i appreciate any help.
@MagicTech, assuming you connect the RFDuino to Serial1, you can have the Spark wait for serial data from the RFduino using:
    if (Serial1.available()) {
      while (Serial.available()) {
        //read the message into an array of chars or whatever, parse it as necessary, etc.
//Otherwise, nothing received so go on with the rest of your loop
You just need to check the serial port as part of your loop(). :smile:
Thank you much again.
It will be wired to Serial2…when that becomes available :wink:
nudge nudge…
Hint received, thanks for the nudge :slight_smile:
Any news on Serial2as yet?
@MagicTech, Serial2 is available on the local build master repo. :smile:
Thanks @peekay123 , Any idea when it will be part of the standard online Build? I have never done a local build.
It’s supposed to be available but the Make file hasn’t been updated since the last time code was pushed to the WEB IDE.
@MagicTech, hopefully on the next production release. @zachary, any comments on this? :smile:
Hey gang,
I’m working on this now as I’m working on bringing the tinker 10 branches into the compile server. It should get released by the end of this sprint. :slight_smile:
Sorry about the long delay!
David
