Sending http header with simple TCPServer
with
using the {} as start and end of data indicator
and the following code in spark
server.println("HTTP-Version: HTTP/1.0 200 OK");
server.println("Content-Length: 8");
server.println("Content-Type: text/html");
server.print("\r\n");
server.println(buf);  // this is the data received excl the {}
just sending the received data back from the spark, I get:
Content-Length: 8
12345678
curl: (28) Operation timed out after 5229 milliseconds with 116 out of -1 bytes received
using the most basic header, sending 8 characters, they come through including the empty line after header… what am I doing wrong? It looks as if the header is not recognized as header, just data (may be)
any pointer or advice welcome
kw
Change that to server.println("HTTP/1.0 200 OK");
and add a server.stop(); to close the connection and you should be fine :smile:
The available() call returns a TCPClient object which comes along with the flow control.
Enjoy! :sunflower:
This seems to work…
[code] server.println(“HTTP/1.0 200 OK”);
// server.println("HTTP-Version: HTTP/1.0 200 OK ");
server.print(“Content-Length: “);
server.println(numberOfChar+2);
server.println(“Content-Type: text/plain “);
server.print(”\r\n{”);
server.print(buf);
server.println(”}”);
[/code]
thx
Karl
curl -d "{1234567890xx}" --max-time 2 192.168.1.204 {1234567890xx}
error message:'class TCPServer' has no member named 'stop'
This seems to work, need delay, if no “delay(10)” it drops some of the characters … between 1… and all
delay(10);
client.stop();
thx for the help
KW
here the complete code (this section)
server.print("Content-Length: ");
server.println("Content-Type: text/plain ");
server.print("\r\n{");
server.print(buf);
server.println("}");
delay(10);
client.stop();
