@krvarma
I tried using winsock and used the Server code to try to connect the core to it.
The server runs fine, the client runs fine(I checked it on the serial monitor) but the client is not able to connect to the server.
On the serial monitor, it says
connecting.....
connection failed.
disconnecting.
and this continues
Here is the server code
#undef UNICODE
#define WIN32_LEAN_AND_MEAN
#include <windows.h>
#include <winsock2.h>
#include <ws2tcpip.h>
#include <stdlib.h>
#include <stdio.h>
// Need to link with Ws2_32.lib
#pragma comment (lib, "Ws2_32.lib")
// #pragma comment (lib, "Mswsock.lib")
#define DEFAULT_BUFLEN 512
#define DEFAULT_PORT "5555"
int __cdecl main(void)
WSADATA wsaData;
int iResult;
SOCKET ListenSocket = INVALID_SOCKET;
SOCKET ClientSocket = INVALID_SOCKET;
struct addrinfo *result = NULL;
struct addrinfo hints;
int iSendResult;
char recvbuf[DEFAULT_BUFLEN];
int recvbuflen = DEFAULT_BUFLEN;
// Initialize Winsock
iResult = WSAStartup(MAKEWORD(2,2), &wsaData);
if (iResult != 0) {
printf("WSAStartup failed with error: %d\n", iResult);
return 1;
ZeroMemory(&hints, sizeof(hints));
hints.ai_family = AF_INET;
hints.ai_socktype = SOCK_STREAM;
hints.ai_protocol = IPPROTO_TCP;
hints.ai_flags = AI_PASSIVE;
// Resolve the server address and port
iResult = getaddrinfo(NULL, DEFAULT_PORT, &hints, &result);
if ( iResult != 0 ) {
printf("getaddrinfo failed with error: %d\n", iResult);
WSACleanup();
return 1;
// Create a SOCKET for connecting to server
ListenSocket = socket(result->ai_family, result->ai_socktype, result->ai_protocol);
if (ListenSocket == INVALID_SOCKET) {
printf("socket failed with error: %ld\n", WSAGetLastError());
freeaddrinfo(result);
WSACleanup();
return 1;
// Setup the TCP listening socket
iResult = bind( ListenSocket, result->ai_addr, (int)result->ai_addrlen);
if (iResult == SOCKET_ERROR) {
printf("bind failed with error: %d\n", WSAGetLastError());
closesocket(ListenSocket);
WSACleanup();
return 1;
iResult = listen(ListenSocket, SOMAXCONN);
printf("listen failed with error: %d\n", WSAGetLastError());
WSACleanup();
return 1;
// Accept a client socket
ClientSocket = accept(ListenSocket, NULL, NULL);
if (ClientSocket == INVALID_SOCKET) {
printf("accept failed with error: %d\n", WSAGetLastError());
WSACleanup();
return 1;
// No longer need server socket
// Receive until the peer shuts down the connection
do {
iResult = recv(ClientSocket, recvbuf, recvbuflen, 0);
if (iResult > 0) {
printf("Bytes received: %d\n", iResult);
// Echo the buffer back to the sender
iSendResult = send( ClientSocket, recvbuf, iResult, 0 );
if (iSendResult == SOCKET_ERROR) {
printf("send failed with error: %d\n", WSAGetLastError());
closesocket(ClientSocket);
WSACleanup();
return 1;
printf("Bytes sent: %d\n", iSendResult);
else if (iResult == 0)
printf("Connection closing...\n");
else {
printf("recv failed with error: %d\n", WSAGetLastError());
WSACleanup();
return 1;
} while (iResult > 0);
// shutdown the connection since we're done
iResult = shutdown(ClientSocket, SD_SEND);
printf("shutdown failed with error: %d\n", WSAGetLastError());
WSACleanup();
return 1;
// cleanup
WSACleanup();
return 0;
here’s the client code
TCPClient client;
byte server[] = { 192, 168, 1, 172 };
byte c;
int port = 5555;
int led = D7;
delay(10000);
pinMode(led, OUTPUT);
Serial.println("connecting...");
if (client.connect(server, port))
Serial.println("connected");
delay(1000);
if(client.read() == 49)
Serial.println("data readed");
digitalWrite(led, HIGH);
delay(10000);
else
Serial.println("data not readed");
digitalWrite(led, LOW);
else
Serial.println("connection failed");
Serial.println();
Serial.println("disconnecting.");
client.stop();
