Hi all
I’m ttly lost concerning procedures and explanations on Twilio.
It exists a Twilio library, but first this lib on GitHub still uses old spark-cli. So here what I done
Twilio account configured, phone number working with text messages
Include the Twilio library in dashboard
Created the webhook using the command
particle webhook create twilio.json
twilio.json is the following (inspired from Hoxworth post Webhooks + Sending a text message){
“eventName”: “twilio”,
“url”: “https://api.twilio.com/2010-04-01/Accounts/xxxxxx/Messages”,
“requestType”: “POST”,
“auth”: {
“username”: “xxxxxx”,
“password”: “xxxxxx”
“form”: {
“From” : “+xxxxxx”,
“To” : “+xxxxxx”,
“Body” : “mouvement detecte”,
“MediaUrl” : “https://dl.dropboxusercontent.com/u/10931735/big_spark-mark-400px.png”
“mydevices”: true
But after to compile it, what command I need to enter ?? the old spark command is not compatible and fails of course. the command to use is
particle compile photon <and_what_??>
PS : to compile and flash it, I suppose I need to do it on the laptop where my Photon is connected. So the Twilio library added in https://build.particle.io/build is used for what ???
I really need your help, since I tried lot of things and don’t succeeded to make it work. THANKS a lot for your feedback !
