SdFat 1.0.16 with SPI1
Hello
I have been trying to use SPI1 for SdFat but have not been successful. The default SPI (on A2-A5) works just fine. Since I will be doing analogRead on analog pins I need to to use Digital pins to write data to SD card.
Here my code
#include <SdFat.h>
#include <SPI.h>
SdFat SD(&SPI1);
File myFile;
const int chipSelect = D5;
  SPI1.begin();
  SD.begin(chipSelect, SD_SCK_MHZ(50));
    SD.wipe(&Serial);
  // Initialize at the highest speed supported by the board
  // Create/Open file
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile)
    // Write to file
    myFile.println("This is a text file");
    myFile.println("From photon");
    myFile.close(); // close the file
    Serial.println("Done.");
  // if the file didn't open, print an error:
  else {
    Serial.println("error opening test.txt");
  // empty
The code basically wipes the SD card then writes a new file to it for now. I’m using Photon for this purpose.
What should I add to have it working with SPI1? Please let me know,
Thank you in advance
Can you be a bit more specific in what way it doesn’t work?
One thing, SPI1 on the Photon (and siblings) does not support 50MHz but only up to 30MHz.
https://docs.particle.io/reference/device-os/firmware/photon/#setclockdividerreference
It’s also not clear why you call SD.begin() twice and SPI1.begin() too?
A signle SD.begin() call should suffice.
And finally you can try a different chipSelect (e.g. A2 which has proven to work with SPI). After establishing whether or not it works with A2 you can find a digital pin to use instead.
BTW, did you know that DAC and WKP can also be used as A6 & A7?
Thanks for the help.
As you stated SPI1 works with 30MHz or less.
I happened to realize for some reason the chipSelect only works with A2.
I didn’t need to call SPI1.begin(), however the second SD.begin() was needed after SD wipe() performed. Otherwise, the setup just deletes things that were on the SD and never writes anything to it.
#include <SdFat.h>
#include <SPI.h>
SdFat SD(&SPI1);
File myFile;
const int chipSelect = A2;
  //SPI1.begin();
  SD.begin(chipSelect, SD_SCK_MHZ(25));
    SD.wipe(&Serial);
    //re initialize after SD wipe.
  // Create/Open file
  if (myFile)
    // Write to file
  else {
  // empty
It might be that "only" D5 is the problem due to it being part of the JTAG pin set but not that A2 is required.
Try some other pins (e.g. D0, D1, RX, TX or any other unused pin)
Got it thank you again,
All the other pins (D0, D1, RX…) do work. it seems just D5 not working.
