Scenario: I want to transfer huge data structures over Serial1 on Boron/Photon2. I am looking at ways to decrease my RAM footprint. Boron/Photon2 the host. Baud rate is 230400 on RS-485 hardware.
Right now I have to allocate about 512 bytes of RAM to the rxBuffer using hal_usart_buffer_config_t acquireSerial1Buffer()
otherwise I end up dropping bytes here and there in long data transfers (think 14kB data transfers).
So I end up with:
512 byte Serial1 rx buffer
14 kB storage buffer to Serial1.read() bytes into
My workflow once I have the whole 14kB packet is to make a pointer to my packet, point it to the address of the storage buffer and then dereference-away.
like this:
//Define longer buffers for the Particle OS USART buffers
const size_t rxBufSize = 512;
const size_t txBufSize = 129;
hal_usart_buffer_config_t config = {
.size = sizeof(hal_usart_buffer_config_t),
.rx_buffer = new (std::nothrow) uint8_t[rxBufSize],
.rx_buffer_size = rxBufSize,
.tx_buffer = new (std::nothrow) uint8_t[txBufSize],
.tx_buffer_size = txBufSize
return config;
typedef big_packet_t{
uint32_t num_1;
//... other members
uint32_t num_N;
}big_packet_t;
void setup(){
Serial1.begin(230400);
//Then send a command out and wait for response
Serial1.write(0x01);
waitUntil(Serial1.available());
//Then read the response into the storage buffer
uint8_t temp_buf[14*1024];
uint8_t* temp_buf_ptr = temp_buf;
while(Serial1.available()){
*temp_buf_ptr++ = Serial1.read();
//Now I can interpret the contents of the buffer as a big_packet_t
big_packet_t* packet = (big_packet_t*)temp_buf;
//And do stuff to the members like
packet->num_1 = 0x12345678;
//Show the contents to the user
Serial.println(packet->num_1);
I'm thinking that I could save 512 bytes of RAM if I could simply de-reference directly from the buffer that Particle OS is using to manage Serial1 RX?
Something like this:
const size_t serial1_rxBufSize = MAX_LINKNET_PACKET_SIZE_BYTES;
extern uint8_t serial1_rxBuf[MAX_LINKNET_PACKET_SIZE_BYTES];
const size_t serial1_txBufSize = 128;
extern uint8_t serial1_txBuf[serial1_txBufSize];
.rx_buffer = serial1_rxBuf,
.rx_buffer_size = serial1_rxBufSize ,
.tx_buffer = serial1_txBuf,
.tx_buffer_size = serial1_txBufSize
return config;
uint32_t num_1;
//... other members
uint32_t num_N;
}big_packet_t;
void setup(){
waitUntil(Serial1.available() < 14*1024); // Wait for 14 kB packet
//No temporary buffer required this time...
//Now I can interpret the contents of the Serial1 rx buffer directly without Serial1.read()
big_packet_t* packet = (big_packet_t*)serial1_rxBuf;
The head scratcher for me is figuring out how to force the Particle OS to reset the write pointer to the beginning of my user-supplied RX buffer after each transaction.
That is the only way that I can dereference the packet directly reliably right? Otherwise the Serial1 drivers will treat the rxBuf that I supply as a circular buffer with the beginning of the packet being anywhere in the buffer. Right?
I have thought of using a
Serial1.end();
After each transaction, however that causes a hardware glitch on our RS-485 network that gets transmitted.
Below scope grab shows the Photon2 TX pin
This glitch screws up the next transaction because it gets interpreted as a start bit by the receiver.
I then played around and tried to see if using pinMode(INPUT_PULLUP) in preventing the glitch when Serial1.end() is called. That didn't work either. Her e is a unit test I made to check if the network glitch is still present with the input pullups enabled:
//UNIT TESTING FUNCTIONS
bool linknet_unit_test_serial1_reinit_effect_on_linknet(void) {
bool initialCheck = linknet_transactions_working();
bool secondCheck = false;
bool afterReinitCheck = false;
bool afterDelayCheck = false;
bool withPullupCheck = false;
bool lastcheck1 = false;
bool lastcheck2 = false;
printHeaderBreak("BEGIN UNIT_TEST_SERIAL1_REINIT_EFFECT_ON_LINKNET",1);
//Prove that back-to-back calls are working
secondCheck = linknet_transactions_working();
//Disable/re-enable serial to force software reset of the rx buffer of Serial1
Serial1.end();
Serial1.begin(LINKNET_BAUD_RATE);
afterReinitCheck = linknet_transactions_working();
//Delay to allow client to reset its UART packet state machine
delay(1000);
//Check if the LinkNet transactions are still working
afterDelayCheck = linknet_transactions_working();
//Now reinit Serial1 with pullup on the RX line
pinMode(TX, INPUT_PULLUP);
Serial1.end();
withPullupCheck = linknet_transactions_working();
delay(1000);
//Now prove once again that back-to-back calls without delay are working
lastcheck1 = linknet_transactions_working();
lastcheck2 = linknet_transactions_working();
//Summarize
printHeaderBreak("END UNIT_TEST_SERIAL1_REINIT_EFFECT_ON_LINKNET",1);
myLog.info("Initial - %s", initialCheck ? "PASS" : "FAIL");
myLog.info("Second - %s", secondCheck ? "PASS" : "FAIL");
myLog.info("After reinit - %s", afterReinitCheck ? "PASS" : "FAIL");
myLog.info("After delay (no re-init)- %s", afterDelayCheck ? "PASS" : "FAIL");
myLog.info("Reinit with pullup - %s", withPullupCheck ? "PASS" : "FAIL");
myLog.info("After delay 2 (no re-init): %s", lastcheck1 ? "PASS" : "FAIL");
myLog.info("Last (no-reinit): %s", lastcheck2 ? "PASS" : "FAIL");
return lastcheck1 && lastcheck2;
And here's the output:
[2025-02-16 00:27:07.007] ========================================
[2025-02-16 00:27:07.020] =BEGIN UNIT_TEST_SERIAL1_REINIT_EFFECT_ON_LINKNET========================================
[2025-02-16 00:27:07.072] 0000003112 [app.linknet] TRACE: linknet packet - addr = 254 | time = 2 ms | cmd = DIRECTORY_BROADCAST (0X01) | rsp = NONE (0x00)
[2025-02-16 00:27:07.136] 0000003172 [app.linknet] TRACE: linknet packet - addr = 254 | time = 2 ms | cmd = DIRECTORY_BROADCAST (0X01) | rsp = NONE (0x00)
[2025-02-16 00:27:07.709] 0000003768 [app.linknet] WARN: Timeout! Received 0 bytes - expected 0 (0x0000)
[2025-02-16 00:27:07.735] 0000003789 [app.linknet] TRACE: linknet packet - addr = 254 | time = 522 ms | cmd = DIRECTORY_BROADCAST (0X01) | rsp = NO_RESPONSE (0xE0)
[2025-02-16 00:27:08.774] 0000004830 [app.linknet] TRACE: linknet packet - addr = 254 | time = 2 ms | cmd = DIRECTORY_BROADCAST (0X01) | rsp = NONE (0x00)
[2025-02-16 00:27:09.305] 0000005364 [app.linknet] WARN: Timeout! Received 0 bytes - expected 0 (0x0000)
[2025-02-16 00:27:09.330] 0000005386 [app.linknet] TRACE: linknet packet - addr = 254 | time = 523 ms | cmd = DIRECTORY_BROADCAST (0X01) | rsp = NO_RESPONSE (0xE0)
[2025-02-16 00:27:10.369] 0000006427 [app.linknet] TRACE: linknet packet - addr = 254 | time = 2 ms | cmd = DIRECTORY_BROADCAST (0X01) | rsp = NONE (0x00)
[2025-02-16 00:27:10.408] 0000006464 [app.linknet] TRACE: linknet packet - addr = 254 | time = 2 ms | cmd = DIRECTORY_BROADCAST (0X01) | rsp = NONE (0x00)
[2025-02-16 00:27:10.444] ========================================
[2025-02-16 00:27:10.456] =END UNIT_TEST_SERIAL1_REINIT_EFFECT_ON_LINKNET========================================
[2025-02-16 00:27:10.482] 0000006541 [app.linknet] INFO: Initial - PASS
[2025-02-16 00:27:10.497] 0000006554 [app.linknet] INFO: Second - PASS
[2025-02-16 00:27:10.508] 0000006567 [app.linknet] INFO: After reinit - FAIL
[2025-02-16 00:27:10.522] 0000006581 [app.linknet] INFO: After delay (no re-init)- PASS
[2025-02-16 00:27:10.540] 0000006599 [app.linknet] INFO: Reinit with pullup - FAIL
[2025-02-16 00:27:10.556] 0000006615 [app.linknet] INFO: After delay 2 (no re-init): PASS
[2025-02-16 00:27:10.575] 0000006633 [app.linknet] INFO: Last (no-reinit): PASS
Is there a better way to simply tell Particle OS to stop filling rx buf, point back to beginning of rxBuf, and then start filling from there again without having to disable the hardware Serial1 peripheral to do it?
Basically, a software reset of Serial1?
Or alternatively, is there a hack that will let me disable/re-enable the whole hardware/software shabang in between transactions without the hardware glitch (I assume this would involve an external pullup resistor?)
