I am still VERY confused @ScruffR, what exactly is the electromagnetic supposed to do, because if I use the Wake on LAN, do I need this?
No, you wonât. There is simply a sensor in your laptop which can detect magnets. There is a magnet in the lid of your laptop. @ScruffR was just suggesting that you could find this magnet and then, using a special electric magnet, copy itâs effect to trick the computer into thinking the lid was open or closed.
Logging it will get problematic since thereâs basically no program that can run before that time which can log you in. With the KISS method in mind, try disabling your password first. Then, set the page youâd like to open as your homepage in your browser. Then, throw a short-cut of that browser into your start-up folder. When your computer boots, it should automatically open that program (your browser), after which the browser will go to the home page.
That might be the cleanest, no-programming, solution out there.
I am going to try this and tell you the results.
How would the log-in work then @Moors7 ?
After using WOL to start the computer, without a password, can WOL log me in?
Do I need to log-off for this to work everytime?
Can I open up two tabs with one shortcut to the browser?
First we'd need to know your operating system.
Assuming it's Windows:
If you have only one user account and remove/clear the password, your computer will most likely directly boot into the system.
If it doesn't there are possibly some minor settings to correct. (EDIT: See this article)
We'd need to know what browser you're using, but most browsers do provide that feature.
BTW: You have been told, that you don't have to ping (@) everybody each and everytime. The guys who have been answering have this thread on their radar already and will drive by from time to time ![]()
Can I buy a single Wemo Switch and put an outlet to it?
Windows.
I am using Chrome, I wanted to know if I can put a shortcut to two tabs in Chrome, so when I log in, it immediately brings up the two tabs.
Okay, sorry!!!
The WeMo has a single outlet. You can attach a power strip if needed however be careful not to exceed the capacity of the switch. You will be controlling the WeMo with your Pi
Windows
Awesome. See this article
Is there a cheaper alternative to the WeMo that is available today?
Also, I am still confused on why I need a Raspberry Pi because with the start up folder that Moors7 suggested I could just add Spotify to that folder and it would open, correct? My only problem is it to begin playing the songs. Can I use IFTTT for that?
Not that I know of. That's why I backed Hook. If you don't have a bunch of lights then you could wire it manually. What kind of light do you have, how many, and how are they connected to power?
If you can get the Laptop method to work then you do not strictly need the Pi however it would
- Make things easier (like turning on your lights)
- Be fun to play with
- Could run spotify so the music plays near instantly when you come downstairs
My Dad's friend works for Hook! ![]()
Can I do this with the Particle Core? is there any way I can do this with start-up scripts or IFTTT?
That awesome! Sounds like you might have an "in" for early access ![]()
Yes, the Core will trigger the event and then the Pi or Start up script can do the rest.
What will the Core trigger exactly? What would the start up script look like to start playing the playlist?
I found an forum post where the code is activated at a certain time, so can i get help to tweak this for the start up script?
#!/bin/bash
spotify 1>/dev/null 2>&1 &
sleep 3
qdbus org.mpris.MediaPlayer2.spotify / org.freedesktop.MediaPlayer2.OpenUri spotify:album:4m2880jivSbbyEGAKfITCa
Well, the Core can send out Wake On Lan packets.
As for the playlist⌠Iâm looking into it. Do you use the web player or the desktop client?
Desktop version. @harrisonhjones
Thank you for your help. Sorry that I couldnât reply earlier, the back of my neck is really stiff and i have to rest
There are relatively cheap 433MHz plug available which you could switch using a Particle with a 433MHz transmitter. If you do a quick forum/Google search for it, there should be plenty examples available.
Any luck?
Success!!!
It worked, perfectly @harrisonhjones How is it going with Spotify?
We might have to build something. The desktop client doesnât look very extendable. Can you go ahead and download Node.js? and install it while making sure you also install NPM?
Sure, quick questionâŚcan I use IFTTT to turn on the lights if I scanned an NFC tag? So if I scan an NFC Tag on the stairs, then it will turn on the WeMo lights?
Yes, that'll work. If you use the, even cheaper, 433MHz plugs, you won't even need IFTTT though, and probably save quite some money. The WeMo is about $45 per outlet, the 433 ones can be had for <$30 for five of them. Just a suggestion, whereby I must mention the WeMo will be easier to setup.
As a quick aside: IFTTT isn't a magic tool, nor a magic wand. Being able to hook some services together, doesn't mean it can hook EVERYTHING together. It's a service to combine online services. If there isn't a channel for it, it's unlikely to work.
I installed the software, what now ?
@harrisonhjones
