I have eventually tracked down a UDP error that occasionally interrupted UDP communications with a Core/Photon server. I cannot offer a cure but I have identified an additional try/except test at the client end that seems to keep things running.
I’ve been using a Core and more recently a Photon as a UDP server to send monitoring data to a PC or Raspberry Pi.
The Particle devices work very reliably but because they occasionally go offline (as far as UDP is concerned) while they renegotiate WiFi or Cloud communications it is necessary to trap socket timeout errors at the client end. Making sure that a socket is connected and then trapping timeout errors reduces crashes from hourly to once in several days but does not eliminate them.
The additional error that needs to be trapped is socket connection refused which was a surprise as it occurs almost immediately after a successful socket.connect() instruction. It took a while to track this down so it is offered here in case anyone else experiences something similar.
With an additional try/except block UDP has been running for weeks now without intervention and traps a socket refused error every couple of days. I guess that sometimes the Particle takes longer than usual to read the request from the client. Perhaps there is a more elegant way to avoid the socket refused.
# Python UDP client code snippet illustrating additional error trapping needed for robust UDP communication
while True:
s = socket.socket(socket.AF_INET,socket.SOCK_DGRAM)
print(s)
s.settimeout(3)
# while we have a socket poll for data from Spark every 15 seconds
while s:
theTime = datetime.now()
#untidy way to start as close as possible to 15.0 secs after last poll
if ((theTime.second % 15 == 0) and (theTime.microsecond <100000)): #it will always take more than 0.1 secs to process my request
print (theTime)
try:
s.connect((host, port)) # connect to Spark server
s.sendall(b'Pi Ready\0 ') # client ready for data
except socket.error:
print('unable to connect')
socketErrors +=1
break
r='not read anything'
try:
r = s.recv(1024)
except socket.timeout:
print ("socket timeout")
timeoutErrors +=1
break
except socket.error, msg: #despite having already trapped socket errors at s.connect we need a second check here
print ("socket refused: %s" % msg)
socketErrors +=1
break
if r == 0: # if r is 0 then the sender has closed for good
print('socket disconnected')
print(s)
break
# should now have received text from server in r
# do stuff with the data - validate and parse etc.
s.close()
The UDP server code is pretty simple - here are the relevant parts:
UDP udp;
unsigned int localPort = 5212; //reserved for incoming traffic
char UDPinData[64];
char UDPoutData[1024];
udp.begin(localPort);
memset(&UDPoutData[0], 0, sizeof (UDPoutData));
// check whether there has been a request to the server and process it
packetSize = udp.parsePacket();
if (packetSize) {
udp.read(UDPinData, 64);
//generate the data to be sent by the particle server here
udp.beginPacket(udp.remoteIP(), udp.remotePort());
sprintf(UDPoutData, "put your formatting and data here %d \n", mydata);
udp.write((unsigned char*)UDPoutData,768); //768 is actual size of data as against buffer size in my case
udp.endPacket();
}//finished writing packet
}//end of loop
