Hi there
I fetched some code from an example elsewhere, but there’s one function I cannot get to work:
String getResponse() {
char rx_buffer[2048];
int bufflen=2048;
int recLen = 0;
memset(rx_buffer, 0, sizeof(rx_buffer));
// wait until data is available, max 5 seconds
uint32_t sT = millis();
while(!client.available() && (millis() - sT) < 5000) {
//delay(1);
recLen = client.available();
if (recLen > 0)
// read from client to the buffer, for length of bytes
for (int i = 0; i < recLen && i < bufflen; i++) {
char rec = client.read();
if (rec == -1) {
break;
rx_buffer[i] = rec;
} else {
return NULL;
// make string from buffer
String rx_string(rx_buffer);
#ifdef RESPONSEDEBUG
Serial.print("[INF] response length: ");
Serial.println(rx_string.length());
#endif
return rx_string;
I get the error when trying to parse it in the editor:
first_project.o: In function getResponse()': /spark/compile_server/shared/workspace/2_compile-server2/core-firmware/build/first_project.cpp:436: undefined reference toString::String(String&&)'
make: *** [bd9a6ffc0b3a229597e71812b072c69237f53f3caeedee0d418b177968cd.elf] Error 1
The sample project I’m partly using is: https://github.com/phhe/sparkSo/blob/master/application.cpp
Any ideas?
BR
Michael
