I’m attempting to use a Pulse Sensor on my Photon, using the PulseSensor_SP community library, but it’s failing to compile on even an empty project.
This is my first time attempting to use external libraries so I’ve probably messed something up, but I cannot figure it out.
Here is the error I’m encountering:
PulseSensor_Spark/SparkIntervalTimer.cpp: In member function 'void IntervalTimer::interrupt_SIT(action)':
PulseSensor_Spark/SparkIntervalTimer.cpp:358:15: warning: variable 'TIMx' set but not used [-Wunused-but-set-variable]
TIM_TypeDef* TIMx;
PulseSensor_Spark/SparkIntervalTimer.cpp: In member function 'void IntervalTimer::start_SIT(intPeriod, bool)':
PulseSensor_Spark/SparkIntervalTimer.cpp:265:43: warning: 'TIMx' may be used uninitialized in this function [-Wmaybe-uninitialized]
TIM_ITConfig(TIMx, TIM_IT_Update, ENABLE);
PulseSensor_Spark/SparkIntervalTimer.cpp: In member function 'void IntervalTimer::stop_SIT()':
PulseSensor_Spark/SparkIntervalTimer.cpp:344:18: warning: 'TIMx' may be used uninitialized in this function [-Wmaybe-uninitialized]
TIM_DeInit(TIMx);
PulseSensor_Spark/SparkIntervalTimer.cpp: In member function 'void IntervalTimer::resetPeriod_SIT(intPeriod, bool)':
PulseSensor_Spark/SparkIntervalTimer.cpp:474:23: warning: 'TIMx' may be used uninitialized in this function [-Wmaybe-uninitialized]
TIMx->PSC = prescaler;
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.pulseTimer+0x0): multiple definition of `pulseTimer'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):/usr/local/gcc-arm-embedded-gcc-arm-none-eabi-4_8-2014q2-20140609-linux-tar-bz2/arm-none-eabi/include/c++/4.8.4/functional:2069: first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.fadeRate+0x0): multiple definition of `fadeRate'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.fadePin+0x0): multiple definition of `fadePin'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.fadePin+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.blinkPin+0x0): multiple definition of `blinkPin'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.blinkPin+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.pulsePin+0x0): multiple definition of `pulsePin'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.pulsePin+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.QS+0x0): multiple definition of `QS'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.Pulse+0x0): multiple definition of `Pulse'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.IBI+0x0): multiple definition of `IBI'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.IBI+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.Signal+0x0): multiple definition of `Signal'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.BPM+0x0): multiple definition of `BPM'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.secondBeat+0x0): multiple definition of `secondBeat'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.firstBeat+0x0): multiple definition of `firstBeat'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.firstBeat+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.amp+0x0): multiple definition of `amp'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.amp+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.thresh+0x0): multiple definition of `thresh'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.thresh+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.T+0x0): multiple definition of `T'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.T+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.data.P+0x0): multiple definition of `P'
../../../build/target/user/platform-6/libuser.a(moretestingpleasework.o):(.data.P+0x0): first defined here
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.lastBeatTime+0x0): multiple definition of `lastBeatTime'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.sampleCounter+0x0): multiple definition of `sampleCounter'
../../../build/target/user/platform-6/libuser.a(PulseSensor_Spark.o):(.bss.rate+0x0): multiple definition of `rate'
make: *** [d594ecf34b0da68919cf867b1e86d6022997ca7d13ef8526b012bf343519.elf] Error 1
