[Resolved] Particle Electron + HTTP POST
Has anyone had any luck with a HTTP Post Library and a Particle Electron? I tried the ‘HttpClient’ library with no luck. A simple code snippet sending to pastebin via HTTP Post would be fab, if anyone has managed it.
…and yes I’m aware this can be done without HTTP Post with Webhooks :wink:
@joearkay, I had no problems using the HTTPClient library on an Electron. I can’t share my code (NDA) but what problems are you having?
Hi @peekay123, thanks for the response. I’ve copied the original example, changed to HTTP Post, attempting to Post to a requestbin, with no luck. Serial debugging is on.
Here’s my code:
#include "HttpClient.h"
#include "application.h"
* Declaring the variables.
HttpClient http;
http_header_t headers[] = {
    { "Content-Type", "application/json" },
http_request_t request;
http_response_t response;
    Serial.println();
    Serial.println("Application>\tStart of Loop.");
    // Request path and body can be set at runtime or at setup.
    request.hostname = "http://requestb.in";
    request.port = 80;
    request.path = "/abcdefg";
    // The library also supports sending a body with your request:
    request.body = "{\"key\":\"value\"}";
    // Get request
    http.post(request, response, headers);
    Serial.print("Application>\tResponse status: ");
    Serial.println(response.status);
    Serial.print("Application>\tHTTP Response Body: ");
    Serial.println(response.body);
    delay(10000);
And here’s the printing from the serial monitor:
Application>    Start of Loop.
Application>    Response status: -1
Application>    HTTP Response Body:
I can’t for the life of me work out what is wrong! Just to clarify, this is a ‘Particle Electron’. @nmattisson could you provide some feedback is it’s your library? :smiley:
Cheers
I’ve solved it!
It was completely trivial, but for anyone with a similar problem…it was the ‘http’ in my hostname, it should be:
request.hostname = "requestb.in";
request.port = 80;
Thanks all for the help!
@peekay123 Turns out the REST Server I’m contacting only accepts HTTPS connections…after all of this! And as far as I’m aware, there isn’t an easy way of implementing HTTPS on a Particle…
Hi @joearkay
Have you seen this post by the Glowfish team?
There is also work in MBED on HTTPS.
Is this usable on the Electron?
Hi @joearkay
I believe that the code should work, but I have not tested it. Get ready for high data usage since that is what happens with HTTPS.
It should be. Alternatively there are also webhooks that enable HTTPS.
That’s what I’m worried about!
