For the Electron, is there a way to determine what causes a Panic reset through code?
Not directly, but you could use backup RAM to store some checkpoint data in your code and in case of a crash check the reset reason and see where about the crash happened.
Usually a panic reset happens due to some coding error and for that reason it wouldn’t really be the device OS’ responsibility to investigate its origin
