Request to https failed with httpClient
Hi everybody
I’m trying to do some requests (mostly POST and GET) to a https host, but every time, this is a failure due to the security of the https.
How can I do a request to this kind of address please ? :smile:
Thanks in advance.
For this you’d need a HTTPSClient - HTTPClient does not support encryption.
But you are in luck as just recently a HTTPSClient has been ported for the Photon.
I guess it’s still WIP, but have a look :wink:
Thanks @ScruffR I’ll take a look at this https client, thanks :smiley:
Unfortunately, I’m working with Parse.com, and I can’t have an ip address, and I don’t have any good result :frowning:
Maybe you could look at the library source at
httpsclientSetup(const char * g_ip_str, const char * host, const char * path);
implementation or a dedicated function that performs a DNS lookup, or you do that yourself or you ping the library owner.
BTW: Have you tried how the function above reacts if you don’t provide a valid IP?
Even if I give to this function a non-valid IP, I still receive some datas. I don’t get some when I’m using parse.com api
Do you have some name of api cloud which provide history for datas ?
