Relay Shield Feedback
If you just need confirmation that the Core received the command and turned on the digital output, you can just track the state of the outputs and return a special code that you look for. You can see an example of that in this very similar 4 digital output remote starter control example that drives 4 small relays (you can read more about it on the github page).
