Refactoring tool for Particle Workbench
I am looking for advice on refactoring tools that work smoothly with workbench? There are a large number of extensions but I am wondering if there are any particle specific issues I need to be aware of…
Many thanks
As long as you are using .cpp files and .h files (instead of .ino files), any of the Marketplace C/C++ source tools will work properly with Particle projects.
If you are using a .ino file, you can convert it to .cpp by renaming it, then:
  • Add #include "Particle.h" at the top
  • Adding forward declarations for any functions implemented after they are used.
