Redis Client Library - Cloud Based Key:Value Store
Hello all, I have ported an Arduino client library for Redis to the :spark: core, giving us a cloud based key:value store.
The original was written by Thomas Lohmüller and can be found here.
From what I can see from my testing most of the Redis protocol works fine and I have been successful running many of the Redis commands.
I will look at further expanding to support subscribing to topics and implementing a callback similar to the MQTT client I posted earlier.
To adapt to your environment change the lines
byte ip[] = { 192, 168, 0, 15 };
uint16_t port = 6379;
I am using a local Redis server, downloadable from here, but no reason why you could not use something on the line. For now here is the code if you are interested in having a play.
  RedisClient.cpp - A simple client library for Redis.
  Original Code - Thomas Lohmüller
  https://github.com/tht/RedisClient
  Adapted for Spark Core by Chris Howard - chris@kitard.com
  See http://redis.io/topics/protocol for details of the redis protocol
  Changes
  - Added gcc pragam to avoid warnings throwing errors (deprecated conversion from string constant to 'char*')
  - Obvious includes commented out / removed
  - Using Spark TCPClient instead of Arduino EthernetClient
  - Updated connect function
  ToDo
  - Investigate Subscribe capability - add callback
  - Move declarations back to .h once Spark IDE fixed
#pragma GCC diagnostic ignored "-Wwrite-strings"
#define ARDUINO_H
#include <stdint.h>
#include <stddef.h>
#include <stdlib.h>
enum RedisResult {
    RedisResult_NONE,
    RedisResult_NOTRECEIVED,
    RedisResult_SINGLELINE,
    RedisResult_ERROR,
    RedisResult_INTEGER,
    RedisResult_BULK,
    RedisResult_MULTIBULK
class RedisClient {
private:
    TCPClient* _client;
    uint8_t *ip;
    char* domain;
    uint16_t port;
    uint8_t _results_waiting;
    RedisResult _resType;
    // internal methods for string manipulation
    inline uint8_t addChar(char* buffer, uint8_t offset, char chr);
    inline uint8_t addData(char *buffer, uint8_t offset, char* str, uint8_t len);
    inline uint8_t addString(char *buffer, uint8_t offset, char* str);
    inline uint8_t addInt(char *buffer, uint8_t offset, int num);
    inline uint8_t addNewline(char *buffer, uint8_t offset);
    // internal methods for construction redis packets in Ethernet Chip's memory
    void startCmd(uint8_t num_args);
    void sendHashArg(char* key, uint16_t index);
    // internal commands to parse redis results
    uint16_t readSingleline(char *buffer);
    uint16_t readInt();
    void flushResult();
    bool connected();
public:
    RedisClient();
    RedisClient(uint8_t *, uint16_t, TCPClient &);
    RedisClient(char *, uint16_t, TCPClient &);
    bool connect();
    // simple commands not needing additional arguments
    uint16_t INCR(char* key);  // returns incremented number
    uint8_t  LTRIM(char* list, int16_t start, int16_t stop); // returns 1 on success
    uint8_t  GET(char* key);   // returns 1 on success, get value using resultBulk(buffer, buflen)
    uint8_t setName(char* clientName);
    // commands needing arguments using sendArg(...) and ending using end*
    uint8_t startPUBLISH(char* channel); // needs one argument
    uint8_t startHSET(char* key);        // needs TWO arguments
    uint8_t startHSET(char* key, uint16_t index); // needs TWO arguments
    uint8_t startRPUSH(char* list);      // needs one argument
    // ... to send arguments for commands above
    void sendArg(char* arg); // to send string which is \0 terminated
    void sendArg(uint8_t* arg, uint8_t len);
    void sendArg(int arg);
    void sendArgRFMData(uint8_t header, uint8_t *data, uint8_t data_len); // format RFM12B packet
    // end commands started using start*
    // all return 1 on success, 0 on failure
    uint8_t endPUBLISH(uint16_t *subscribers);
    uint8_t endPUBLISH();
    uint8_t endHSET();
    uint8_t endRPUSH(uint16_t *listitems);
    uint8_t endRPUSH();
    // read back results
    RedisResult resultType();
    uint16_t resultInt();
    uint16_t resultStatus(char *buffer);
    uint16_t resultError(char *buffer);
    uint16_t resultBulk(char *buffer, uint16_t buffer_size);
extern char* itoa(int a, char* buffer, unsigned char radix);
// Constructor
RedisClient::RedisClient() {
   this->_client = NULL;
RedisClient::RedisClient(uint8_t *ip, uint16_t port, TCPClient& client) {
   this->_client = &client;
   this->ip = ip;
   this->port = port;
   this->domain = NULL;
RedisClient::RedisClient(char* domain, uint16_t port, TCPClient& client) {
   this->domain = domain;
   this->port = port;
// CONNECT
bool RedisClient::connect() {
   if (!connected()) {
      int result = 0;
      if (domain != NULL) {
        result = _client->connect(this->domain, this->port);
      } else {
        result = _client->connect(this->ip, this->port);
      if (!result) {
          _client->stop();
          return false;
      return true;
   } else {
      flushResult();
   return false;
uint16_t RedisClient::INCR(char* key) {
    connect();
    _resType = RedisResult_NOTRECEIVED;
    startCmd(2);
    sendArg("INCR");
    sendArg(key);
    return resultInt();
uint8_t RedisClient::LTRIM(char* list, int16_t start, int16_t stop) {
    connect();
    startCmd(4);
    sendArg("LTRIM");
    sendArg(list);
    sendArg(start);
    sendArg(stop);
    return resultType() == RedisResult_SINGLELINE;
uint8_t RedisClient::GET(char* key) {
    connect();
    startCmd(2);
    sendArg("GET");
    sendArg(key);
    return resultType() == RedisResult_BULK;
uint8_t RedisClient::setName(char* clientName) {
    connect();
    startCmd(3);
    sendArg("client");
    sendArg("setname");
    sendArg(clientName);
uint8_t RedisClient::startPUBLISH(char* channel) {
    connect();
    startCmd(3);
    sendArg("PUBLISH");
    sendArg(channel);
uint8_t RedisClient::startHSET(char* key) {
    connect();
    startCmd(4);
    sendArg("HSET");
    sendArg(key);
uint8_t RedisClient::endPUBLISH(uint16_t *subscribers) {
    if (resultType() == RedisResult_INTEGER) {
        *subscribers = resultInt();
        return 1;
    } else {
        return 0;
uint8_t RedisClient::endPUBLISH() {
    uint16_t subscribers;
    return endPUBLISH(&subscribers);
uint8_t RedisClient::endHSET() {
        resultInt(); // throw away result
        return 1;
    } else {
        return 0;
uint8_t RedisClient::endRPUSH(uint16_t *listitems) {
        *listitems = resultInt();
        return 1;
    } else {
        return 0;
uint8_t RedisClient::endRPUSH() {
    uint16_t listitems;
    return endPUBLISH(&listitems);
uint8_t  RedisClient::startHSET(char* key, uint16_t index) {
    char buffer[30];
    uint8_t offset = addString(buffer, 0, key);
    offset = addChar(buffer, offset, ':');
    offset = addInt(buffer, offset, index);
    offset = addChar(buffer, offset, '\0');
    startHSET(buffer);
uint8_t RedisClient::startRPUSH(char* list) {
    connect();
    startCmd(3);
    sendArg("RPUSH");
    sendArg(list);
RedisResult RedisClient::resultType() {
    if (_resType == RedisResult_NOTRECEIVED) {
        while(! _client->available() )
            delay(1);
        switch( _client->read() ) {
            case  '+': _resType = RedisResult_SINGLELINE; break;
            case  '-': _resType = RedisResult_ERROR; break;
            case  ':': _resType = RedisResult_INTEGER; break;
            case  '$': _resType = RedisResult_BULK; break;
            case  '*': _resType = RedisResult_MULTIBULK; break;
    if (_resType > RedisResult_NOTRECEIVED)
        return _resType;
    return RedisResult_NONE;
uint16_t RedisClient::readInt() {
    uint16_t res = 0;
    char chr;
    while(1) {
            delay(1);
        chr = _client->read();
        if (chr >= '0' && chr <= '9') {
            res *= 10;
            res += chr - '0';
        } else if (chr == '\r') {
            // ignore
        } else if (chr == '\n') {
            _resType = RedisResult_NONE;
            return res; // returning result
uint16_t RedisClient::resultInt() {
    if (resultType() != RedisResult_INTEGER)
        return 0;
    return readInt();
uint16_t RedisClient::readSingleline(char *buffer) {
    char chr;
    uint8_t offset = 0;
    while(1) {
            delay(1);
        if (chr >= 32 && chr <= 126) {
            buffer[offset++] = chr;
            // ignore
            buffer[offset++] = '\0';
            return offset; // returning length of string
uint16_t RedisClient::resultStatus(char *buffer) {
    if (resultType() != RedisResult_SINGLELINE)
        return 0;
    return readSingleline(buffer);
uint16_t RedisClient::resultError(char *buffer) {
    if (resultType() != RedisResult_ERROR)
        return 0;
// Note: buffer_size has to be bigger than result as result there'll be always a \0 appendet
uint16_t RedisClient::resultBulk(char *buffer, uint16_t buffer_size) {
    if (resultType() != RedisResult_BULK)
        return 0;
    uint16_t result_size = readInt();
    while(_client->available() < result_size+2)
        delay(1);
    _client->read((uint8_t*)buffer, result_size);
    buffer[result_size] = '\0';
    // throw away newline
    _client->read(); _client->read();
    return result_size;
void RedisClient::flushResult() {
    switch (resultType()) {
        case RedisResult_SINGLELINE:
        case RedisResult_ERROR:
            char buffer[200];
            break;
        case RedisResult_INTEGER:
            readInt();
            break;
inline uint8_t RedisClient::addChar(char* buffer, uint8_t offset, char chr) {
    buffer[offset] = chr;
    return offset+1;
inline uint8_t RedisClient::addData(char *buffer, uint8_t offset, char* str, uint8_t len) {
    memcpy( buffer+offset, str, len);
    return offset + len;
inline uint8_t RedisClient::addString(char *buffer, uint8_t offset, char* str) {
    return addData(buffer, offset, str, strlen(str));
inline uint8_t RedisClient::addInt(char *buffer, uint8_t offset, int num) {
    itoa(num, buffer+offset, 10);
    return offset + strlen(buffer+offset);
inline uint8_t RedisClient::addNewline(char *buffer, uint8_t offset) {
    buffer[offset++] = '\r';
    buffer[offset++] = '\n';
    return offset;
void RedisClient::sendArg(uint8_t* arg, uint8_t len) {
    char buffer[20];
    uint8_t offset = 0;
    offset = addChar(buffer, offset, '$');
    offset = addInt(buffer, offset, len);
    offset = addNewline(buffer, offset);
    _client->write((uint8_t*)buffer, offset);
    _client->write(arg, len);
    offset = 0;
void RedisClient::sendHashArg(char* key, uint16_t index) {
    char buffer[30];
    sendArg((uint8_t*)buffer, offset);
void RedisClient::sendArg(char* arg) {
    sendArg((uint8_t*)arg, strlen(arg));
void RedisClient::sendArg(int arg) {
    char buffer[20];
    uint8_t offset = addInt(buffer, 0, arg);
void RedisClient::startCmd(uint8_t num_args) {
    char buffer[20];
    uint8_t offset = 0;
    // preparing argument count
    offset = addChar(buffer, offset, '*');
    offset = addInt(buffer, offset, num_args);
void RedisClient::sendArgRFMData(uint8_t header, uint8_t *data, uint8_t data_len) {
    char buffer[200];
    uint8_t offset = 0;
    offset = addString(buffer, offset, "OK ");
    offset = addInt(buffer, offset, header);
    for (int i=0; i<data_len; i++) {
        offset = addChar(buffer, offset, ' ');
        offset = addInt(buffer, offset, data[i]);
bool RedisClient::connected() {
   bool rc;
   if (_client == NULL ) {
      rc = false;
   } else {
      rc = (int)_client->connected();
      if (!rc) _client->stop();
   return rc;
TCPClient tcpClient;
RedisClient client(ip, port, tcpClient);
    client.connect();
    client.setName("Spark");
    // Add some interesting stuff here
    // Examples here --> https://github.com/tht/RedisClient
Chris
This. Is. BRILLIANT!!!
I think I’ll give this a try tonight. I like the idea of the cores pushing data to Redis and having a listener BLPOP to relay my sensor data instead of polling at fixed intervals. I’ll post back and let you know how it goes.
great! :smile: i will try it out soonish.
( It would be great if you could post it on github, so it is easy to contribute patches and make forks. )
Reviving an old topic…
I’m trying to connect my Spark Core to a local Redis server, and not having much luck. My issues:
  • If I include the .connect() method call, my Spark locks up. If I leave it out, things seem to work anyway, seemingly automatically connecting on the first .GET call.
  • However, if I execute a GET, but the key doesn’t exist in the Redis server, my spark locks up upon calling resultBulk()
Has anyone successfully used this Redis library, and can give me some pointers?
