I’ve got a very simple bit of code that listens for UDP packets and uses them to turn the LED attached to digital pin 7 on or off.
This code works fine on my two Cores, however when I run the same code on my Photon it never receives any UDP packets. Is there anything different I need to do for the Photon to receive UDP messages?
Here is my code:
int led = D7;
// UDP Port used for two way communication
unsigned int localPort = 12348;
// An UDP instance to let us send and receive packets over UDP
UDP Udp;
pinMode(led, OUTPUT);
// start the UDP
Udp.begin(localPort);
// Print your device IP Address via serial
delay(1000); //to give the serial port time to open
Serial.println(WiFi.localIP());
Serial.println(WiFi.SSID());
Serial.println(localPort);
// Check if data has been received
if (Udp.parsePacket() > 0)
// Read first char/byte of data received
int i = Udp.read();
Serial.println(i);
// Ignore other chars
Udp.flush();
//set LED based on received data
if (i == 0)
digitalWrite(led, LOW);
else if (i == 1)
digitalWrite(led, HIGH);
Hey guys! I asked and this is being worked on for the next Photon release. I know a github issue was created based on this thread so that will help track it, but it was being looked at before.
Thanks a lot. I understand full well what it’s like to have dozens of different “issues” pulling at you. . .and prioritizing becomes difficult. Debugging is a full time job!
Is there a thread or github issue we can track for Photon UDP support? Looking forward to porting my quadcopter project to the Photon but it relies on UDP.
Hi
I wrote a piece of code that listens on UDP packets, it works under certain scenarios (e.g., when it’s the main code in the sketch). But when I tried adding my code into another existing piece of code (https://github.com/sparcules/Spark_Pixels/blob/master/Firmware/SparkPixels.ino) I never get anything back from parsePacket(). I wonder if there’s something obvious I may have overlooked.
#include "neopixel/neopixel.h"
//NEOPIXEL Defines
#define PIXEL_CNT 512
#define PIXEL_PIN D0
#define PIXEL_TYPE WS2812B
#define NR_OF_PANELS 8
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_CNT, PIXEL_PIN, PIXEL_TYPE);
// An UDP instance to let us receive packets over UDP
UDP Udp;
// Define some tpm2.net constants
#define TPM2NET_LISTENING_PORT 65506
#define TPM2NET_HEADER_SIZE 6
#define TPM2NET_HEADER_IDENT 0x9C
#define TPM2NET_CMD_DATAFRAME 0xDA
#define TPM2NET_CMD_COMMAND 0xC0
#define TPM2NET_CMD_ANSWER 0xAC
#define TPM2NET_FOOTER_IDENT 0x36
#define TPM2NET_PACKET_TIMEOUT 0xFA // 1/4 of a second
#define PIXELS_PER_PANEL (PIXEL_COUNT / NR_OF_PANELS)
// 3 bytes per pixel or 24bit (RGB)
#define BPP 3
// Package size we expect. The footer byte is not included here!
#define EXPECTED_PACKED_SIZE (PIXELS_PER_PANEL * BPP + TPM2NET_HEADER_SIZE)
float timeLastPacketReceived;
cube.begin();
cube.background(black);
cube.show();
// Start the UDP
if(Udp.setBuffer(EXPECTED_PACKED_SIZE))
Udp.begin(TPM2NET_LISTENING_PORT);
// Checks for the presence of a UDP packet, and reports the buffer size
int32_t bytes = Udp.parsePacket();
* I want any smaller packets to be ignored. This is intentional because
* the TMP2.NET protocol dictates a fixed packet size. It works as expected.
if(bytes >= EXPECTED_PACKED_SIZE) {
// Read 198 bytes of data from the buffer
char data[EXPECTED_PACKED_SIZE];
Udp.read(data, EXPECTED_PACKED_SIZE);
// Ignore all other chars
Udp.flush();
timeLastPacketReceived = millis();
/*-- Header check --*/
// Block Start Byte
if(data[0] == TPM2NET_HEADER_IDENT) {
// Block Type: Command Packet
if(data[1] == TPM2NET_CMD_COMMAND)
return; // Don't care
// Block Type: Frame Data Packet - that's what we want
if(data[1] == TPM2NET_CMD_DATAFRAME) {
// Calculate frame size
char frameSize = data[2];
frameSize = (frameSize << 8) + data[3];
// Use packetNumber to calculate offset
char packetNumber = data[4];
char totalPackets = data[5];
// Calculate offset
uint16_t index = packetNumber * PIXELS_PER_PANEL;
uint16_t voxelIdx = TPM2NET_HEADER_SIZE;
// Start drawing!!
for(uint16_t z = NR_OF_PANELS-1; z >= 0; z--) { // We're only dealing in 2 dimensions (width & height)
for(uint16_t col = 0; col < NR_OF_PANELS; col++) { // Linewise, starting from leftmost index
for(uint16_t row = NR_OF_PANELS - 1; row >= 0; row--) { // Columnwise, starting from topmost index
uint16_t stripIdx = (row * PIXELS_PER_PANEL) + (z * NR_OF_PANELS) + col;
// Take 3 color bytes from buffer
strip.setPixelColor(stripIdx, strip.Color(data[voxelIdx], data[voxelIdx + 1], data[voxelIdx + 2])); //(z, col, row, pixelColor);
voxelIdx+=3; // Increment buffer index by 3 bytes
if(stop == TRUE) {return;}
// Display!!
if(packetNumber == totalPackets) {strip.show();}
else if(millis() - timeLastPacketReceived > TPM2NET_PACKET_TIMEOUT) {
// No data, nothing to do
for(uint16_t i=0; i<strip.numPixels(); i++)
strip.setPixelColor(i, 0); // Turn Off all pixels
strip.show();
You posted this also in a github issue in the firmware repo. For discussions like this regarding problem solving some code, this forum is the ideal place!
Thanks for letting me know. It was exactly for not knowing this that I’ve posted it on both these forums and github (following a link from an earlier post by loopj in here).
