Hello,
I can only do Reading A Variable " ON_OFF ," Do I need a reading Variable reset_52 NOT I can in my HTML page . How do paragraph Skip SEVERAL variables ?
Annex following code .
Thank you ,
FAbripaz
Thank you,
FAbripaz
Hello,
Thank you ,
FAbripaz
Thank you,
FAbripaz
So you want to access 2 cloud variables in that jQuery code ?
Most straight forward way is to nest the calls.
$.get("url1", function(data) {
$.get("url2", function(data2) {
//do stuff here
An alternative could be to make one variable that is a json string and parse that.
Just for the future:
@fabripaz, if you post code or text excerpts, could you please avoid doing it as screenshots but add the actual text in a text block like
```text
copy-paste your text here
or a code block like
```cpp
```cpp
// copy-paste your code here
This also allows people to take your code and test it, if needed.
