Hello friends. There is my issue, I have a sensor which has ADC 24 bits data through SPI, could I receive (SPI) and send (Wifi) these same 24 bits? (Since the ADC of the spark core is 12 bits).
By the way, I’m new working with the Spark core. Regards.
@afromero, if your sensor is SPI based then reading it will not be a problem.
Sending the data in the format of your choice will also work just fine and there are many ways to do that with Spark.variables(), Spark.publish(), TCPClient, UDP, etc.
Here’s a quick guide for getting you up and running
- Search the internet for an Arduino or C/C++ library for your sensor model. If it exists you may be able to port it to the Spark Core very easily. Jump to Step 6.
- Get your sensor datasheet and review the commands required to access your ADC inputs.
- Review the SPI Documentation and determine what speed, mode and commands are needed for reading your ADC: http://docs.spark.io/firmware/#communication-spi
- Start with a sketch/application that just works on setting up the SPI and talking to your sensor, and printing values to the Serial or Serial1 port of your choice.
- Wrap up these commands in a C++ Class (aka Library) to make it easier to use.
- Now that you have a working Library for your sensor, add WiFi connectivity by using Spark.variables(), Spark.function() or Spark.publish() http://docs.spark.io/firmware/#cloud-functions-data-and-control
Once you get to coding and debugging, let us know if you run into any roadblocks. I’m sure there’s bound to be a few things that pop up!
