Reading multiple pins in html and jquery.
Good morning everybody.
I’m developing a tool to control photon pins by html and javascript. I already have html code that works perfectly fine for a single pin. The code allows you to click on a particular pin and at the same time reports via html the current status of the pin. The problem is they are multiple pins and I don’t really know how to return the multipin state via get. The code below reports the status of a single pin but how to do it for the logic level of more than one pin. My difficulty is in “function(data, status)” returning data from multiple variables and pins.
<html>
<head>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js" type="text/javascript" charset="utf-8"></script>
<script>
var accessToken = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
var deviceID = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
var url = "https://api.spark.io/v1/devices/" + deviceID + "/IoT";
$(document).ready(function(){
$("button").click(function(){
$.get(url, {access_token: accessToken}, function(data, status){
statusPin = parseInt(data.result);
alert("Data: " + statusPin + "\nStatus: " + status);
//$("p").html("Data: " + statusPin + "\nStatus: " + status);
if(statusPin == 1){
$("p").html("On");
if(statusPin == 0){
$("p").html("Off");
function switchD7()
$.post(url, {params: "D7", access_token: accessToken });
function switchD6()
$.post(url, {params: "D6", access_token: accessToken });
</script>
</head>
<body>
<button>click here to check the status of the photon</button>
<p>Status do photon.</p>
<input type="button" onClick="switchD7()" value="click here to check the status of the led"/>
<input type="button" onClick="switchD6()" value="click here to check the status of the led"/>
</body>
</html>
int ledPin7 = D7;
int statusPin7;
pinMode(ledPin7, OUTPUT);
Spark.function("IoT", ledSwitch);
Spark.variable("IoT", &statusPin7, INT);
int ledSwitch(String command) {
if (command.equalsIgnoreCase("D7")){
statusPin7 = !statusPin7; // toggle the value
digitalWrite(ledPin7, statusPin7);
return 1;
return -1;
Below to interact with two pins
int ledPin7 = D7;
int statusPin7;
int ledPin6 = D6;
int statusPin6;
pinMode(ledPin6, OUTPUT);
Spark.variable("IoT", &statusPin6, INT);
return 1;
if (command.equalsIgnoreCase("D6")){
statusPin6 = !statusPin6; // toggle the value
digitalWrite(ledPin6, statusPin6);
return 1;
return -1;
-1;
