Reading a serial buffer for an item
I would appreciate the community's help as I am not a C programmer. I have read numerous tutorials on serial programming but could not find what I am looking for. Namely, reading the value of each item in the serial buffer.
I am reading from a serial sensor using:
int len;
char buf[60];
len = Serial1.readBytes((char *)buf,50);
if(len > 0)
for (int i=0; i <= len; i++)
if (buf[i] == 170)
I need to loop over the entire buffer and look for an entry = 170. (Hex = AA).
How can I print the value of each item in the buffer so I can see the stream? I tried sending the buffer items by using String(buf[0]) but I am getting gibberish.
Thanks in advance.
@Jimmie
String(buf[0])
This will convert the index 0 of the char array to a C String object. If you print a non-printable character value you will get gibberish!
Serial.printlnf("Buffer value [%i] = %i", i, buf[i]);
Should output Buffer value [10] = 170
What you want to do is format the char value as a hex or integer string. Also, char is really an ascii character value (7 bits) and you want to read values of >127 - so better to use uint8_t or byte.
In terms of looking for 170 value you could try using the Stream class findUntil() - examples in the firmware reference.
Thank you @armor for your time but I did not understand. If my code is
int len;
char buf[60];
if(len > 0)
       if (buf[i] == 170)
What should this statement be?
int len;
char buf[60];
len = Serial1.readBytes((char *)buf,sizeOf(buf));
if(len > 0)
       if (buf[i] == 170)
           Serial.printlnf("Buffer value [%i] = 170", i);
           //do something else that you want to ??
       else
I do not know what you want to do when you find char = 170?
Thank you @armor. I am seeing the stream using Particle Dev on my PC.
I have been trying to print the buf[i] value to the cloud to see what I am getting. If I may bother you with one request, how does one print the value to the cloud?
In setup() you could declare a cloud variable - these must be of type String, integer, or double.
If you want to output a char then you could convert it to a String or an integer - integer would be;
int cloudVarInt = 0;
...your code
Particle.variable("name", cloudVarInt);
...your code
cloudVarInt = (int) buf[i];  //type cast char to int
Thank you very much @armor. I think I got it now.
I appreciate it.
