I’m working with this library and I need to be able to send/receive unsigned bytes. I can send them with Serial1.write but I’m unable to read them. I’ve tried looping with Serial1.read, casting with Serial1.readBytes and basically every possible way to read the serial I can think of but all I’m getting is garbage. Is there any native way to read to an unsigned char buffer on the elctron?
@jcole, do you have a link to the actual code?
I don't quite see this issue
I've tried to write and read bytes with this code and a TX-RX loopback and it works as expected
uint8_t buf[256];
uint8_t inbuf[256];
Serial.begin(115200);
Serial1.begin(9600);
for (uint8_t i=0; i<30;i++)
buf[i] = i;
Serial1.write(buf, 30);
delay(100);
Serial1.readBytes((char*)inbuf, 255);
for(int i=0; i<30; i++)
delay(5);
Serial.printf("0x%02x ", inbuf[i]);
Serial.println();
The thing to take into account is the 64byte RX/TX buffer tho' (observer the "missing" 0x3f
entry in each block)
Yeah, I don’t know. I went from getting garbage to getting no response at all. I just contacted the link labs people so hopefully they can shed some light.
