Hi Guys,
So I have been able to get my Pi to send messages successful over and over to the Electron.
Pi = Master
Electron = Slave
that is the way it is setup at this time.
When I try to make a request to the Electron to send me a queued message I am struggling
include <Wire.h>
define MyAddress 0x40
byte DataToBeSend[1];
bool OutgoingMessageNeedsProcessing = false;
bool IncommingMessageNeedsProcessing = false;
bool IncommingMessageRequestHelp = false;
bool GPSMessageNeedsProcessing = false;
bool MessageStart = false;
String aString;
String aStringToSend;
String LastTrailHelp;
/* Initialize I2C Slave & assign call-back function 'onReceive' on 'I2CReceived'*/
Wire.begin(MyAddress);
Wire.onReceive(I2CReceived);
Wire.onRequest(I2CRequest);
// Particle.publish("GPSData", "Start Up Applicationv5", PRIVATE);
Particle.subscribe("Help", HelpHandler);
void HelpHandler(const char *event, const char *data)
LastTrailHelp = String(data);
if(OutgoingMessageNeedsProcessing)
if(GPSMessageNeedsProcessing)
GPSMessageNeedsProcessing=false;
aStringToSend = aStringToSend.replace("~ENDGPS~","").replace("~STARTGPS~","");
Particle.publish("GPSData", aStringToSend, PRIVATE);
aStringToSend="";
delay(1000);
else
OutgoingMessageNeedsProcessing=false;
delay(1000);
/* This function will automatically be called when RPi2 sends data to this I2C slave */
void I2CReceived(int NumberOfBytes)
// Serial1.write("Data Recieved");
/* WinIoT have sent data byte; read it */
while(0 < Wire.available()) { // loop through all
String wire = ConvertToAscii(Wire.read());
aStringToSend = aStringToSend + wire;
DataToBeSend[0] =2;
if(strstr(aStringToSend,"~ENDGPS~"))
MessageStart=false;
OutgoingMessageNeedsProcessing=true;
GPSMessageNeedsProcessing=true;
DataToBeSend[0] =1;
Wire.write(DataToBeSend,1);
else if(strstr(aStringToSend,"~RM:HELP~"))
//Would send data to the PI here
Wire.write("~START~");
Wire.write("NO DATA");
Wire.write("~END~");
void SendRequestData()
/* This function will automatically be called when RPi2 requests for data from this I2C slave */
void I2CRequest()
/*Send data to WinIoT */
String ConvertToAscii(char c)
switch (c)
case 32:
return " ";
break;
case 33:
return "!";
break;
case 34:
return "\"";
break;
case 35:
return "#";
break;
case 36:
return "$";
break;
case 37:
return "%";
break;
case 38:
return "&";
break;
case 39:
return "'";
break;
case 40:
return "(";
break;
case 41:
return ")";
break;
case 42:
return "*";
break;
case 43:
return "+";
break;
case 44:
return ",";
break;
case 45:
return "-";
break;
case 46:
return ".";
break;
case 47:
return "/";
break;
case 48:
return "0";
break;
case 49:
return "1";
break;
case 50:
return "2";
break;
case 51:
return "3";
break;
case 52:
return "4";
break;
case 53:
return "5";
break;
case 54:
return "6";
break;
case 55:
return "7";
break;
case 56:
return "8";
break;
case 57:
return "9";
break;
case 58:
return ":";
break;
case 59:
return ";";
break;
case 60:
return "<";
break;
case 61:
return "=";
break;
case 62:
return ">";
break;
case 63:
return "?";
break;
case 64:
return "@";
break;
case 65:
return "A";
break;
case 66:
return "B";
break;
case 67:
return "C";
break;
case 68:
return "D";
break;
case 69:
return "E";
break;
case 70:
return "F";
break;
case 71:
return "G";
break;
case 72:
return "H";
break;
case 73:
return "I";
break;
case 74:
return "J";
break;
case 75:
return "K";
break;
case 76:
return "L";
break;
case 77:
return "M";
break;
case 78:
return "N";
break;
case 79:
return "O";
break;
case 80:
return "P";
break;
case 81:
return "Q";
break;
case 82:
return "R";
break;
case 83:
return "S";
break;
case 84:
return "T";
break;
case 85:
return "U";
break;
case 86:
return "V";
break;
case 87:
return "W";
break;
case 88:
return "X";
break;
case 89:
return "Y";
break;
case 90:
return "Z";
break;
case 91:
return "[";
break;
case 92:
return "\\";
break;
case 93:
return "]";
break;
case 94:
return "^";
break;
case 95:
return "_";
break;
case 96:
return "'";
break;
case 97:
return "a";
break;
case 98:
return "b";
break;
case 99:
return "c";
break;
case 100:
return "d";
break;
case 101:
return "e";
break;
case 102:
return "f";
break;
case 103:
return "g";
break;
case 104:
return "h";
break;
case 105:
return "i";
break;
case 106:
return "j";
break;
case 107:
return "k";
break;
case 108:
return "l";
break;
case 109:
return "m";
break;
case 110:
return "n";
break;
case 111:
return "o";
break;
case 112:
return "p";
break;
case 113:
return "q";
break;
case 114:
return "r";
break;
case 115:
return "s";
break;
case 116:
return "t";
break;
case 117:
return "u";
break;
case 118:
return "v";
break;
case 119:
return "w";
break;
case 120:
return "x";
break;
case 121:
return "y";
break;
case 122:
return "z";
break;
case 123:
return "{";
break;
case 124:
return "|";
break;
case 125:
return "}";
break;
case 126:
return "~";
break;
default:
return "~~~";
break;
What I want to do is take a subscription message and send it to the PI however i think I need to and queue it and the PI will need to query and pull the data…
Does anyone know a better way for 2 way communication to where the electron could init a message to be sent to the pi vs the pi pulling it.
