Random Number generation between range
Hi everyone.
I’m looking for the spark equivalent of rand/random().
I notice that the web IDE recognises the keyword rand() but I’m looking to specify the range of numbers to select from.
I am trying to get a random number between 0 and 9.
The compiler doesn’t like rand(0,9) or random(0,9) and reports too many arguments error.
Similarly, I tried rand(9) assuming the minimum bound defaults to 0. Same error.
Any clues?
Thanks in advanced.
Joni
HI Joni,
I have been using the following for now. Gives random between 1 and maxRand. Remove the +1 for 0 to maxRand.
int random(int maxRand)
    return rand() % maxRand + 1;
Txs
Chris
I did quick fact check with previous post, but didn’t notice Google gave me GCC Fortran page instead of GCC C++. I have used so many languages I always mix details if I haven’t coded for a while. :confused:
If you like to extend @Kitard’s function with minimum value, it should be:
int random(int minRand, int maxRand)
return rand() % (maxRand-minRand+1) + minRand;
The result includes both minRand and maxRand. If Spark supports full C++, you should be able to include both 1- and 2-argument versions if you like.
I created a full example if anyone needs something like this:
#include "application.h"
// Uncomment for faster debugging!
//#include "spark_disable_wlan.h"
int random(int maxVal);
int random(int minVal, int maxVal);
// returns a random integar between 0 and maxVal
  return random( 0, maxVal);
// returns a random integar between minVal and maxVal
  // int rand(void); included by default from newlib
  return rand() % (maxVal-minVal+1) + minVal;
void setup(void) {
  Serial.begin(115200); // Make sure your serial terminal is closed before power the Core.
  while(!Serial.available()) { // Open serial terminal and Press ENTER.
    #ifdef SPARK_WLAN_SETUP
      SPARK_WLAN_Loop();
    #endif
  // Waiting for a human to start the program at a random time...
  // humans are so very random :P
  uint32_t seed = millis();
  srand(seed); // void srand(unsigned int seed);
  // Generate a random number, from 1 - 10.
  int random_num = random(1,10);
  // Generate a random number, from 0 - 10.
  //int random_num = random(10);
  char bar[10] = "";
  int random_copy = random_num;
  while(random_copy > 0) {
    strcat(bar,"="); // Create a bargraph
    random_copy--;
  // Scroll our bargraph in the serial terminal
  Serial.print(bar);
  Serial.print(" ");
  Serial.println( random_num );
  delay(100);
Thank you man, this worked for me!
Just an update, now this is also supported for anyone who has the same question but wants a single command line
MyRandNumber = random(0,7); //picks number between 0 and 7
Errr (Correction)
MyRandNumber = random(0,7); //picks number between 0 and 6
