Questions about Cell Strength vs Quality Boron BRN402 vs BRN404
You probably have the wrong antenna like I do. Boron BRN402 vs BRN404 setup issues
I was able to get mine to connect, but the signal is not as good as the 402. If I get the 'correct' antenna in I will let you know if it's any better.
