Question in context with Adafruit 4-Digit 7-Segment Display with I2C Backpack
In context with my published project on the 7 segment display, I have left me two challenges unanswered, to which I know no answer:
My primary question is, can I switch on/off the LED display (I need it at night only for a few seconds via a PIR motion sensor or touch sensor to activate the display; otherwise it will be permanently switched off.)?
My second question is, how can I manipulate the display to also outputs the representation of a leading 0 during hour 0 (0:03 instead of x:x3)?
    // Get the current time in HHMM format
    the_time = Time.hour()*100+Time.minute();
    //Serial.println(the_time);
In order to display leading zeros you may need to print the time digit by digit and not as number.
This also allows you to print an empty string (together with stopping the seconds toggle of the colon) to switch the display off - or you set the brightness to 0.
You can surely print leading zeros using snprintf?
A long long time ago I did this:
It uses the Adafruit library for the i2c backpack, which includes a setBrightness command that takes 0-15 as input values.
By the way, that Core-based project is still running on my desk at home.
Thx for example and helpful hints: solved the point with the leading zeros as follow:
    // Display the time in 24 hour format
    if(TWENTYFOUR_HOUR==1) {
        matrix.print(the_time);
        if (Time.hour() == 0) {
             matrix.writeDigitNum(1, 0); // = first value = number of digit - in this case = second digit, starts with 0 to 4; second value = value to display
        if (Time.minute() <= 9) {
             matrix.writeDigitNum(3, 0); // = first value = number of digit - in this case = third digit, starts with 0 to 4; second value = value to display
Yes, the brightness is set by this command:
matrix.setBrightness(brightness); // max brightness: 15
but also with brightness = 0 the display is on and shines a bit bright.
I look at the strings again.
