I have a web page that’s running a javascript script then placing the output in the body of my web page in a div. I was wondering if it was possible to use the particle to take the contents of the div and then publish them in serial? The page reloads every so often, so I would want that text to be read everytime the page reloads.
I have experience with javascript but am new to Particle.
If you have to parse through a ton of data, you may want to try to create a simple stripped-down file/page that serves up from the same server but at an alternate file extension. Wehn you update your page, update the micro-page (very simple JSON object on yourserver.com/data.json) and then parse that simplified page...
Have you Particle go up every so often with some url query string argument that gets photon the right little page.
or if you are good at php a little script to strip out the data server-side.
