PublishQueueExtRK testing
I am testing some of my old code with the new library: PublishQueueExtRk and withPublishCompleteUserCallback()
In my code, with PublishQueuePosixRK, I was able to pet the Watchdog when publishing was successful. Am I doing something wrong with the new library? I have not used a CloudEvent object yet. Perhaps I should get that going? Thanks for your help!
This log below shows the Watchdog timing out, no refresh:
0000011205 [system] INFO: Cloud connected
0000011206 [system.ledger] INFO: Subscribing to ledger updates
0000011209 [comm] INFO: Forcing a cloud ping
0000011422 [system.ledger] INFO: Subscribed to ledger updates
0000030000 [app] INFO: publish some info
0000060000 [app] INFO: publish some info
0000090000 [app] INFO: publish some info
0000120000 [app] INFO: publish some info
0000150000 [app] INFO: publish some info
0000180000 [app] INFO: publish some info
0000210000 [app] INFO: publish some info
0000240000 [app] INFO: publish some info
0000270000 [app] INFO: publish some info
0000300000 [app] INFO: publish some info
Serial connection closed.
my code:
//  Device OS 6.3.0
//  Particle Argon
#include "Particle.h"
#include "PublishQueueExtRK.h"
//  v(0.0.4)
#ifndef SYSTEM_VERSION_v620
SYSTEM_THREAD(ENABLED);
#endif
SYSTEM_MODE(AUTOMATIC);
SerialLogHandler logHandler(LOG_LEVEL_INFO);
const std::chrono::milliseconds g_oneMinuteInterval =     1min;
char g_szPublishEventData[particle::protocol::MAX_EVENT_DATA_LENGTH];
static retained uint32_t g_magick = 0;
  PublishQueueExt::instance().setup();
  PublishQueueExt::instance().withPublishCompleteUserCallback([](bool succeeded, const char *eventName, const char *eventData) {
    if (succeeded)  {
      Watchdog.refresh();
      Log.info("Refresh the watchdog... an event was successfully published with ACK: %s", eventName);
    } else  {
      Log.error("Publish failed: %s", eventName);
  PublishQueueExt::instance().withFileQueueSize(25);
  waitFor(Serial.isConnected, 5000);
  delay(1000);
  uint timeOutInMinutes = 5;
  uint32_t msTimeoutWatchdog = timeOutInMinutes * g_oneMinuteInterval.count();
  Watchdog.init(WatchdogConfiguration().timeout(msTimeoutWatchdog));
  Watchdog.onExpired([]() {
      g_magick++;
  Watchdog.start();
  snprintf(g_szPublishEventData, sizeof(g_szPublishEventData), "timeout=%dmin", timeOutInMinutes);
  PublishQueueExt::instance().publish("hardware_watchdog", g_szPublishEventData);
  PublishQueueExt::instance().loop();
  static uint32_t lastLogTime = 0;
  if (millis() - lastLogTime >= 30000)
    lastLogTime = millis();
    Log.info("publish some info");
    PublishQueueExt::instance().publish("some_event", "Some data.");
0.0.5 (2025-04-11)
  • Added support for withPublishCompleteUserCallback(). It was not previously implemented, though the call to set it was left over from PublishQueuePosixRK. The new prototype only has a CloudEvent object you can use the determine success or failure, the event name, or the event data.
     * @brief Adds a callback function to call with publish is complete
     * @param cb Callback function or C++ lambda.
     * @return PublishQueueExt&
     * The callback has this prototype and can be a function or a C++11 lambda, which allows the callback to be a class method.
     * void callback(const CloudEvent &event)
     * The parameters are:
     * - event: The CloudEvent object that was just sent
     * You can determine success/failure, examine the event. or the event data, by using methods of the CloudEvent class
     * Note that this callback will be called from the background thread used for publishing. You should not
     * perform any lengthy operations and you should avoid using large amounts of stack space during this
     * callback.
    PublishQueueExt &withPublishCompleteUserCallback(std::function<void(const CloudEvent &event)> cb) { publishCompleteUserCallback = cb; return *this; };
