Publishing a value to Mosquitto
Hey everyone
I am a newbie working with the Particle and have managed to publish a series of messages to mosquito but actually need the values of the sensor not just a message …some help would be greatly appreciated
the code
#include "MQTT/MQTT.h"
#include "math.h"
const int ledPin1 = D1 ;
const int ledPin2 = D2 ;
const int analogInPin1 = A0;
const int analogInPin2 = A1;
#define ThermisterPin 2
char message_buff[100];
char* tempC;
double Thermistor(int RawADC) {
double Temp;
Temp = log(12000.0 * ((1024.0 / RawADC - 1)));
Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp )) * Temp );
Temp = Temp -273.15;//Convert Kelvin to Celcius
//Temp = (Temp * 9.0) / 5.0 + 32.0;//Convert Celcius to Fahrenheit
return Temp;
int sensorValue = 0;
int outputValue = 0;
int ledState = LOW;
int ledState2 = LOW;
void callback(char* topic, byte* payload, unsigned int length);
// if want to use IP address,
 byte server[] = { 192,168, 1,108 };
 MQTT client(server, 1883, callback);
// recieve message
void callback(char* topic, byte* payload, unsigned int length) {
    char p[length + 1];
    memcpy(p, payload, length);
    p[length] = NULL;
    String message(p);
    if (message.equals("RED"))
        RGB.color(255, 0, 0);
    else if (message.equals("GREEN"))
        RGB.color(0, 255, 0);
    else if (message.equals("BLUE"))
        RGB.color(0, 0, 255);
    else
        RGB.color(255, 255, 255);
    delay(1000);
    RGB.control(true);
    // connect to the server
    client.connect("sparkclient");
    // publish/subscribe
    if (client.isConnected()) {
        client.publish("outTopic/message","hello world");
        client.subscribe("inTopic/message");
    pinMode(ledPin1, OUTPUT);
    pinMode(ledPin2, OUTPUT);
    Serial.println(int(Thermistor(analogRead(0))));//display Fahrenheit
    delay(1000);
    float t1 = analogRead(analogInPin1);
    sensorValue = analogRead(analogInPin1);
    outputValue = map(sensorValue, 0, 5000, 0, 255);
    Serial.println(sensorValue);
    if (sensorValue < 3000) {
        digitalWrite (ledPin2, HIGH);
        digitalWrite (ledPin1, LOW);
        client.publish("mymosquitto/Particle", "Larry Happy");
        delay(3000);
    else if (sensorValue > 3000) {
        digitalWrite (ledPin1, HIGH);
        digitalWrite (ledPin2, LOW);
        client.publish("mymosquitto/Particle", "Larry needs Water");
        delay(3000);
    Serial.println("connected");
        client.loop();
What have you tried and isn’t working?
sprintf() would be a keyword to look up (in standard C/C++ manuals/tutorials)
Hey Guys below is the code Im using for my Arduino and it is publishing via an Ethernet card .when I paste the formulae and modify it to collect the values I get an error
if (!client.connected())
  tempC = dtostrf(((((analogRead(tempPinIn) * .5) / 1023) - 0.5) * 100), 5, 2, message_buffer);
  if (millis() > (time + 6000)) {
    time = millis();
    client.publish("mymosquitto/arduino/temperature2", tempC);
    Serial.print(tempC);
  //  tempC1 = dtostrf(((((analogRead(tempPinIn1) * 5.0) / 1024) - 0.5) * 100), 5, 2, message_buffer);
  //  if (millis() > (time + 7000)) {
  //    time = millis();
  //    client.publish("mymosquitto/arduino/soilsensor", tempC1);
  //    Serial.print(tempC1);
  tempC2 = dtostrf(((((analogRead(tempPinIn1) * 10.0) / 1024) - 0.5) * 100), 5, 2, message_buffer);
  Serial.print(" %\t");
  if (millis() > (time + 5000)) {
    time = millis();
    client.publish("mymosquitto/arduino/lightsensor", tempC2);
    Serial.print(tempC2);
  client.loop();
  if (!client.connected()) {
    reconnect();
  client.loop();
  //check if 5 seconds has elapsed since the last time we read the sensors.
  if (millis() > readTime + 20000) {
    sensorRead();
void sensorRead() {
  readTime = millis();
  float h1 = dht1.readHumidity();
  float h2 = dht2.readHumidity();
 // float h3 = dht3.readHumidity();
  float t1 = dht1.readTemperature();
  float t2 = dht2.readTemperature();
//  float t3 = dht3.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f1 = dht1.readTemperature(true);
  float f2 = dht2.readTemperature(true);
//  float f3 = dht3.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h1) || isnan(t1) || isnan(f1)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  char buffer[10];
  dtostrf(t1, 0, 0, buffer);
  client.publish("mymosquitto/arduino/temperature1", buffer);
  Serial.println(buffer);
  dtostrf(h1, 0, 0, buffer);
  client.publish("mymosquitto/arduino/humidity1", buffer);
  //client.publish("inTopic/humidity",sprintf(buf, "%f", h));
  Serial.print("Humidity1: ");
  Serial.print(h1);
  Serial.print("Temperature1: ");
  Serial.print(t1);
  Serial.print(" *C ");
  delay(1000);
  if (isnan(h2) || isnan(t2) || isnan(f2)) {
    return;
  // Compute heat index in Fahrenheit (the default)
  //  float hif = dht.computeHeatIndex(f2, h2);
  // Compute heat index in Celsius (isFahreheit = false)
  //  float hic = dht.computeHeatIndex(t2, h2, false);
  //  char buffer[10];
  dtostrf(t2, 0, 0, buffer);
  client.publish("mymosquitto/arduino/temperature2", buffer);
  dtostrf(h2, 0, 0, buffer);
  client.publish("mymosquitto/arduino/humidity2", buffer);
  Serial.print("Humidity2: ");
  Serial.print(h2);
  Serial.print("Temperature2: ");
  Serial.print(t2);
  delay(1000);
 // if (isnan(h3) || isnan(t3) || isnan(f3)) {
 //   Serial.println("Failed to read from DHT sensor!");
 //   return;
  //char buffer[10];
//  dtostrf(t3, 0, 0, buffer);
//  client.publish("mymosquitto/arduino/temperature3", buffer);
//  Serial.println(buffer);
//  dtostrf(h3, 0, 0, buffer);
//  client.publish("mymosquitto/arduino/humidity3", buffer);
  //client.publish("inTopic/humidity",sprintf(buf, "%f", h3));
//  Serial.print("Humidity3: ");
//  Serial.print(h3);
 // Serial.print(" %\t");
 // Serial.print("Temperature3: ");
//  Serial.print(t3);
//  Serial.print(" *C ");
//  delay(10000);
the problem is this string here
dtostrf(t1, 0, 0, buffer); Particle doesn't know what this is ..(I barely do) lol
Sure, you can try anything but the suggested solutions :wink:
I use sprint() as @ScruffR suggested
char message[56];
sprintf(message, "%d--%3.2f Supply voltage | %d--%3.2f Battery voltage", supplyAnalogValue, supplyVoltage, batteryAnalogValue, batteryVoltage);
mqttClient.publish(eventTopic, message);
thanks guys ill give it a shot
OK Guys thanks a lot for your help here is the publishing code to share
#include "math.h"
#include <stdio.h>
const int ledPin3 = D7 ;
char* tempC;
char* Temp;
double Temp;
return Temp;
int main ()
  char buffer [100];
  int n, a=5, b=3;
  n=sprintf (buffer, "%d plus %d is %d", a, b, a+b);
  printf ("[%s] is a string %d chars long\n",buffer,n);
  return 0;
int sensorValue2 = 0;
int outputValue2 = 0;
int ledState = LOW;
int ledState3 = HIGH;
// recieve message
    char p[length + 1];
    p[length] = NULL;
    String message(p);
    else
    delay(1000);
    RGB.control(true);
    pinMode(ledPin3, OUTPUT);
char message[56];
sensorValue2 = analogRead(analogInPin2);
outputValue2 = map(sensorValue, 0, 5000, 0, 255);
Serial.println(sensorValue2);
sprintf(message, " %d ", sensorValue2);
client.publish("mymosquitto/Particle2", message);
   sprintf(message, " %d " , sensorValue );
   client.publish("mymosquitto/Particle1", message);
    if (sensorValue < 1400) {
        delay(10000);
    else if (sensorValue > 1400) {
        delay(10000);
        client.loop();
//#include "lib1.h"
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "Adafruit_DHT.h"
#define DHTPIN 0     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11		// DHT 11
#define DHTTYPE DHT22		// DHT 22 (AM2302)
char* message;
int main ()
  char buffer [100];
  int n, a=5, b=3;
  return 0;
int sensorValue3 = 0;
int sensorValue4 = 0;
int ledState = LOW;
DHT dht(DHTPIN, DHTTYPE);
	Serial.println("DHT22 test!");
	dht.begin();
// Wait a few seconds between measurements.
delay(2000);
char message[56];
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a
// very slow sensor)
	float h = dht.getHumidity();
// Read temperature as Celsius
	float t = dht.getTempCelcius();
// Read temperature as Farenheit
	float f = dht.getTempFarenheit();
	if (isnan(h) || isnan(t) || isnan(f)) {
		return;
// Must send in temp in Fahrenheit!
	float hi = dht.getHeatIndex();
	float dp = dht.getDewPoint();
	float k = dht.getTempKelvin();
	Serial.print("Humid: ");
	Serial.print(h);
	Serial.print("% - ");
	Serial.print("Temp: ");
	Serial.print(t);
	Serial.print("*C ");
	Serial.print(f);
	Serial.print("*F ");
	Serial.print(k);
	Serial.print("*K - ");
	Serial.print("DewP: ");
	Serial.print(dp);
	Serial.print("*C - ");
	Serial.print("HeatI: ");
	Serial.print(hi);
	Serial.println("*C");
	sensorValue3 = (t);
	sprintf(message, " %d ", sensorValue3);
	Particle.publish("Temperature", message, PRIVATE);
	sensorValue4 = (h);
	sprintf(message, " %d ", sensorValue4);
	Particle.publish("Humididty" , message ,PRIVATE);
Particle.publish("mymosquitto/Particle2", message);
    Particle.publish("mymosquitto/Particle1", message);
        Particle.publish("mymosquitto/Particle", "Larry Happy");
        delay(1000);
        Particle.publish("mymosquitto/Particle", "Larry needs Water");
        delay(1000);
Serial.println(Time.timeStr());
