Publish local ip to the cloud
How can I modify this code to publish my Photon’s ip once every ten seconds?
while(!Serial.available()) Particle.process();
// Prints out the local IP over Serial.
Serial.println(WiFi.localIP());
how about trying something like this:
IPaddress myLocalIP = WiFi.localIP();
char message[64] = ""
sprintf(message, "My Local IP= %d:%d:%d:%d", myLocalIP[0],, myLocalIP[1], myLocalIP[2], myLocalIP[3]);
Particle.publish("myLocalIP", message);
I got some errors
test.cpp:1:1: error: ‘IPaddress’ does not name a type
test.cpp:3:1: error: expected ‘,’ or ‘;’ before ‘sprintf’
test.cpp:4:1: error: ‘Particle’ does not name a type
#line 1
make[1]: *** […/build/target/user/platform-6test.o] Error 1
make: *** [user] Error 2
Flash unsuccessful.
a few typos…
  IPAddress myLocalIP = WiFi.localIP();
  char message[64] = "";
  sprintf(message, "My Local IP= %d:%d:%d:%d", myLocalIP[0], myLocalIP[1], myLocalIP[2], myLocalIP[3]);
There are a still some more
test.cpp:3:10: error: expected constructor, destructor, or type conversion before ‘(’ token
test.cpp:4:3: error: ‘Particle’ does not name a type
#line 1
Error: Could not compile. Please review your code.
compiled fine for me:
int lastUpdate = 0;
    if(millis() - lastUpdate > 10000UL)  // 10 seconds
        lastUpdate = millis();
It worked for me now. Thanks you are awesome!
