Process kill method non functional
Hi
There’s a problem with the Process kill method in that the kill is sent to the sh process - but not the child process - rendering this method non functional
I’ve crudely worked around as follows
kill (xProcess.pid () + 1, SIGTERM);
xProcess.kill ();
however this is not a robust solution - scanning /proc/ and matching parent pid would be more robust - but I wonder it if might be simpler to just dispense with the sh indirection? - that would solve this problem and improve efficiency - another way to solve this - and be more compatible - would be to generate a unique process group id for the sh process and then just kill that - currently the process group id inherits from the firmware
Regards
Julian
Hi
My better workaround is as follows
xProcess.kill ();
system ("killall childProcessName");
Regards
Julian
Interesting finding. Could you please open a new GitHub issue with the code reproduce this so we can solve this? Thanks!
