hello good day forum
I have a question to solve, as I am reading through the serial port I receive too much information, and this causes the routine to be activated up to 14 times. I tried to use if but it didn’t work, now I show you with switch case:
#include <Servo.h>
Servo myservo;
char lectura;
int ENA = 10;
int IN1 = 9;
int IN2 = 8;
int ENB = 5;
int IN3 = 6;
int IN4 = 7;
pinMode (ENA, OUTPUT);
pinMode (ENB, OUTPUT);
pinMode (IN1, OUTPUT);
pinMode (IN2, OUTPUT);
pinMode (IN3, OUTPUT);
pinMode (IN4, OUTPUT);
myservo.attach(3);
myservo.write(45);
delay(1000);
if(Serial.available() > 0){ //Olfatea la comunicacion serial
lectura = Serial.read();
Adelante();
switch (lectura) {
case '1':
myservo.write(0);
delay(1000);
break;
case '2':
myservo.write(75);
delay(1000);
break;
case '3':
delay(6000);
Parada();
Izquierda();
delay(8000);
Derecha();
delay (8000);
Parar();
break;
void Derecha () {
//Direccion motor A
digitalWrite (IN1, HIGH);
digitalWrite (IN2, LOW);
analogWrite (ENA, 255); //Velocidad motor A
void Adelante () {
//Direccion motor A
digitalWrite (IN3, LOW);
digitalWrite (IN4, HIGH);
analogWrite (ENB, 255); //Velocidad motor A
void Parada() {
//Direccion motor A
digitalWrite (IN4, LOW);
analogWrite (ENB, 0); //Velocidad motor A
void Izquierda () {
//Direccion motor A
digitalWrite (IN1, LOW);
digitalWrite (IN2, HIGH);
void Parar () {
//Direccion motor A
analogWrite (ENA, 0); //Velocidad motor A
Any advice to solve it?
(added by Moderator: in a - now removed - parallel post this was another question to that same/very similar code)
