I’m trying to take photo after attaching camera at Electron 3g module, and upload the photo to firebase storage.
By writing json file, I tried to upload it using ‘webhook create’ order, but following error had occurred.
“Error Webhook creation failed: url must use a valid protocol and not reference private hostnames”
This is the following Json code (https://github.com/rickkas7/firebase_tutorial is been referred.)
"event": "uploadPicture",
"url": "gs://firebase-testUpload.appspot.com/pict.json",
"requestType": "POST",
"query": {
"auth":"-"
"json": {
"BUFFER": "{{BUFFER}}"
"mydevices": true,
"noDefaults": true
This is the Json code operate properly which sending GPS coordinate and the time.
"event": "testGPS",
"url": "https://fir-testUpload.firebaseio.com/TEST0001/GPS.json",
"query": {
"auth":"-"
"json": {
"LAT": "{{LAT}}",
"LNG": "{{LNG}}",
"TS": "{{PARTICLE_PUBLISHED_AT}}"
"mydevices": true,
"noDefaults": true
If what I’m thinking now is correct, it seems like the part of the url which starts with ‘gs’ is the one with the problem.
Is there any solution for this?
