cbrake
November 26, 2019, 9:52pm
1
Running on an Argon with deviceOS@1.4.1 …
Trying to configure WiFI settings via BLE:
Serial.println("ssid is too long");
return;
strncpy(buf, (char*)data, len);
buf[len] = 0;
Serial.printf("set wifi SSID: %s\n", buf);
setSSID = buf;
static void onSetWifiPass(const uint8_t* data, size_t len, const BlePeerDevice& peer, void* context)
char buf[100];
if (len > sizeof(buf)) {
return;
buf[len] = 0;
Serial.printf("set wifi pass: %s\n", buf);
WiFi.clearCredentials() always returns false, but it seems like the credentials are cleared.
When I run the method to change the wifi settings, the device is stuck on fast blink green, or may be fast blink cyan.
Once I reset the device, it connects fine to the new network.
Is there any way I can force the wifi to connect to a new network without restarting?
ScruffR
November 26, 2019, 9:57pm
2
Have you tried WiFi.off() after storing the new settings and then WiFi.on() again?
cbrake
November 26, 2019, 10:18pm
3
I tried adding Wifi.off/on (see below). It still stays on fast blinking green LED, so no change. After reset, connects fine.
char buf[100];
return;
buf[len] = 0;
if (PLATFORM_ID == PLATFORM_ARGON) {
WiFi.disconnect();
if (!WiFi.clearCredentials()) {
Serial.println("Failed to clear Wifi credentials");
if (!WiFi.setCredentials(setSSID.c_str(), buf)) {
Serial.println("Failed to set Wifi credentials");
} else {
Serial.println("WiFi credentials set");
wifiSSIDCharacteristic.setValue(setSSID);
WiFi.off();
WiFi.on();
Particle.connect();
//System.reset();
Try using a delay() after the WIFi.off() - I suspect that the module is not completing the off process before trying to set it on again. Start with a 2s value and test.
armor
November 27, 2019, 2:23pm
5
In my experience with the Photon the following delay periods work well after WiFi.clearCredentials()
WiFi.off();
delay(20);
WiFi.on();
delay(100);
Not so sure with the Argon but certainly longer than no delay. Generally I have found it a good idea to insert a delay after WiFi.on(); and calling WiFi.connect() which I would do before checking for wifi.ready and calling Particle.connect().
