Problem with SparkFun LiPo Fuel Gauge (MAX17043)
I modified the sparkfun fuel gauge by removing the 1k cell sensor and adding an external 1k to the Lipo from the max17043’s cell pin. The board’s vcc is connected to particle’s 3.3 volt. The board seems to work fine in this configuration.
@idreams Hey!! how did you solve this?! I’m stuck!
@DanCuartas ,
Are you using this with the Photon as well?
Chip
