Problem with Particle.variable format by 0.5.0-rc1
I noticed a problem with new firmware.
This format gives strange results:
Particle.variable(“startstate”, startstate);
This format works great:
Particle.variable(“startstate”, &startstate, INT);
More details please! What’s the type of variable you’re passing in? What’s strange about the results?
To reproduce this here is a simple example.
int startstate = 0;
void setup ()
//Particle.variable("startstate ", & Startstate, INT);
Particle.variable ( "startstate", startstate);
void loop ()
I get the following result instead of zero.
{cmd: “VarReturn”, name: “startstate”, result: 134498903,…}
cmd
"VarReturn"
coreInfo
{last_app: “”, last_heard: “2016-04-07T18:45:34.509Z”, connected: true,…}
name
"startstate"
result
134498903
Thanks! Confirmed this is an issue in 0.5.0-rc.1
There is a workaround, described in the issue.
