Trying to figure out what is going on. I have tried setting up the basic photoresistor code and was not seeing any change in the LED. So I threw the tinker code onto the core and measured the analogRead setting for pin A0. It always stays ~300-330 regardless of the amount of light shined on it. Even when I replace the resistor with wire and put a digital high signal into it from A5 it still does not change from the ~300-330 reading. I have tested this with two different photons and the tinker script. Is there something wrong with the AnalogRead?
The currently published Tinker.ino file doesn't work right with the Photon. See this thread for more info:
If you do as I mention in my original post, and remove this line (from function tinkerAnalogRead, line 62):
pinMode(pinNumber+10, INPUT);
You'll get accurate reads.
Here’s the version of Tinker that comes on the Photon, and works:
From: https://github.com/spark/firmware/blob/latest/user/src/application.cpp
* @file application.cpp
* @authors Satish Nair, Zachary Crockett and Mohit Bhoite
* @version V1.0.0
* @date 05-November-2013
* @brief Tinker application
Copyright (c) 2013-2015 Particle Industries, Inc. All rights reserved.
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation, either
version 3 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this program; if not, see <http://www.gnu.org/licenses/>.
/* Includes ------------------------------------------------------------------*/
#include "application.h"
#include "stdarg.h"
/* Function prototypes -------------------------------------------------------*/
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
int tinkerAnalogRead(String pin);
int tinkerAnalogWrite(String command);
SYSTEM_MODE(AUTOMATIC);
/* This function is called once at start up ----------------------------------*/
//Setup the Tinker application here
//Register all the Tinker functions
Spark.function("digitalread", tinkerDigitalRead);
Spark.function("digitalwrite", tinkerDigitalWrite);
Spark.function("analogread", tinkerAnalogRead);
Spark.function("analogwrite", tinkerAnalogWrite);
/* This function loops forever --------------------------------------------*/
* Function Name : tinkerDigitalRead
* Description : Reads the digital value of a given pin
* Input : Pin
* Output : None.
* Return : Value of the pin (0 or 1) in INT type
Returns a negative number on failure
//convert ascii to integer
int pinNumber = pin.charAt(1) - '0';
//Sanity check to see if the pin numbers are within limits
if (pinNumber< 0 || pinNumber >7) return -1;
if(pin.startsWith("D"))
pinMode(pinNumber, INPUT_PULLDOWN);
return digitalRead(pinNumber);
else if (pin.startsWith("A"))
pinMode(pinNumber+10, INPUT_PULLDOWN);
return digitalRead(pinNumber+10);
return -2;
* Function Name : tinkerDigitalWrite
* Description : Sets the specified pin HIGH or LOW
* Input : Pin and value
* Output : None.
* Return : 1 on success and a negative number on failure
bool value = 0;
int pinNumber = command.charAt(1) - '0';
if(command.substring(3,7) == "HIGH") value = 1;
else if(command.substring(3,6) == "LOW") value = 0;
else return -2;
if(command.startsWith("D"))
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, value);
return 1;
else if(command.startsWith("A"))
pinMode(pinNumber+10, OUTPUT);
digitalWrite(pinNumber+10, value);
return 1;
else return -3;
* Function Name : tinkerAnalogRead
* Description : Reads the analog value of a pin
* Input : Pin
* Output : None.
* Return : Returns the analog value in INT type (0 to 4095)
return -3;
return analogRead(pinNumber+10);
return -2;
* Function Name : tinkerAnalogWrite
* Description : Writes an analog value (PWM) to the specified pin
* Input : Pin and Value (0 to 255)
* Output : None.
String value = command.substring(3);
analogWrite(pinNumber, value.toInt());
return 1;
analogWrite(pinNumber+10, value.toInt());
return 1;
else return -2;
Many thanks.
when users hit the reflash tinker button in a mobile app as well as the copy in CLI?
